Adafruit 7 Segemtn backpack help
johnmap12
Re: Adafruit 7 Segemtn backpack help
Post by johnmap12 »
Website doesn't allow ino extention attachment.
Here's the code:
#include "Wire.h" // Enable this line if using Arduino Uno, Mega, etc.
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_7segment matrix = Adafruit_7segment();
int CodeIn;// used on all serial reads
int KpinNo;
int Koutpin;
String KoldpinStateSTR, KpinStateSTR, Kstringnewstate,Kstringoldstate;
String altit, altitold, vertsp, vertspold, hdgset, hdgsetold, flaps, flapsold;
#ifndef __AVR_ATtiny85__
  Serial.begin(115200);
  #endif
  matrix.begin(0x70);
    if (Serial.available()) {
    CodeIn = getChar();
    if (CodeIn == '=') {EQUALS();} // The first identifier is "="
    if (CodeIn == '<') {LESSTHAN();}// The first identifier is "<"
    if (CodeIn == '?') {QUESTION();}// The first identifier is "?"
    if (CodeIn == '/') {SLASH();}// The first identifier is "/" (Annunciators)
  }//end of serial read bit
}//end of void loop
char getChar()// Get a character from the serial buffer
  while(Serial.available() == 0);// wait for data
  return((char)Serial.read());// Thanks Doug
void EQUALS(){
  char tmpChar;
  CodeIn = getChar(); // Get the second identifier
  switch(CodeIn) {// Now lets find what to do with it
      case 'd': // found AP heading setting
      delay (11);
      hdgset = "";
      tmpChar = getChar();
      matrix.print(tmpChar);
      hdgset += tmpChar;
      hdgset += tmpChar;
      matrix.println(tmpChar);
      hdgset += tmpChar;
      matrix.writeDisplay();
      hdgsetold = hdgset;
    }//end of case switch
  }// end of void equals
void LESSTHAN(){    // The first identifier was "<"
CodeIn = getChar(); // Get another character
    case 'A'://Found the second identifier
       //Do something
    break;
    case 'B':
       //Do something
    break;
    case 'F':
       // Do something
    break;
    case 'G'://Found the second identifier ("G" Flaps position)
      // Do something
    break;
      }//end of case method
   }//end of lessthan
void QUESTION(){    // The first identifier was "?"
//do something
}// end of question
void SLASH(){    // The first identifier was "/" (Annunciator)
  //Do something
Last edited by adafruit_support_rick on Thu Jul 17, 2014 11:07 am, edited 1 time in total.
Reason: please use Code tags when posting code (</> button)
Post by adafruit_support_rick »
Why are you calling getChar three times before you print it? That's why you're only getting the third character printed out on the matrix.
Maybe there's something I'm not understanding here. Doesn't your input look like "=d123"?
      delay (11);
      hdgset = "";
      hdgset += tmpChar;
johnmap12
Post by johnmap12 »
Hi Rick
I forgot to mention that I sorted the code out.
Here's fully working code:
#include "math.h"
#include "Quadrature.h"
Adafruit_7segment matrix1 = Adafruit_7segment();
Adafruit_7segment matrix2 = Adafruit_7segment();
Adafruit_7segment matrix3 = Adafruit_7segment();
Quadrature quad1(12, 11); // Course
Quadrature quad2(10, 9); // Speed
Quadrature quad3(8, 7); // Heading
Quadrature quad4(6, 5); // Altitude
int KpinNo;
int Koutpin;
int Count;
int AP_crs_set[3];
int AP_speed_kt_set[3];
int AP_hdg_set[3];
String Digit;
String altit, altitold, vertsp, vertspold, hdgset, hdgsetold, flaps, flapsold, spd, spdold, crs, crsold;
int R;// a variable
int Rold;// the old reading
int Rdif;// the difference since last loop
int R2;// a second test variable
int R3;// a second test variable
int R4;// a second test variable
int Rold2;// a second loop old reading
int Rdif2; // the second test difference
int Rold3;// a second loop old reading
int Rdif3; // the second test difference
int Rold4;// a second loop old reading
int Rdif4; // the second test difference
  #endif
  matrix1.begin(0x71);  //70 Course
  matrix2.begin(0x71);  //70 Speed
  matrix3.begin(0x70);  //70 Heading
  for (int PinNo = 22; PinNo <= 70; PinNo++)// Get all the INPUT pins ready.
    pinMode(PinNo, INPUT);
    digitalWrite(PinNo, HIGH);
  {KEYS();} //Check the "keys" section
  {ENCODER();} //Check the Rotary Encoders
  if (Serial.available()) {// Check if serial data has arrived from PC
    CodeIn = getChar();
    if (CodeIn == '<') {LESSTHAN();}// The first identifier is "<" Indications
    if (CodeIn == '?') {QUESTION();}// The first identifier is "?"  Systems2
void EQUALS(){
  case 'e':    //  AP course set
       Count = 0;
        while (Count < 3)
          Digit = "";
          Digit += getChar();
          AP_crs_set[Count] = Digit.toInt();
          Count++;
            matrix1.writeDigitNum(1,AP_crs_set[0]);
            matrix1.writeDigitNum(3,AP_crs_set[1]);
            matrix1.writeDigitNum(4,AP_crs_set[2]);
            matrix1.writeDisplay();
           crsold = crs;
        case 'f':    //  AP speed knots set kts
       Count = 0;
        while (Count < 3)
          Digit = "";
          Digit += getChar();
          AP_speed_kt_set[Count] = Digit.toInt();
          Count++;
            matrix2.writeDigitNum(1,AP_speed_kt_set[0]);
            matrix2.writeDigitNum(3,AP_speed_kt_set[1]);
            matrix2.writeDigitNum(4,AP_speed_kt_set[2]);
            matrix2.writeDisplay();
           spdold = spd;
      case 'd':    //  AP heading set
       Count = 0;
        while (Count < 3)
          Digit = "";
          Digit += getChar();
          AP_hdg_set[Count] = Digit.toInt();
          Count++;
            matrix3.writeDigitNum(1,AP_hdg_set[0]);
            matrix3.writeDigitNum(3,AP_hdg_set[1]);
            matrix3.writeDigitNum(4,AP_hdg_set[2]);
            matrix3.writeDisplay();
          hdgsetold = hdgset;
       //Do something
    break;
    case 'B':
       //Do something
    break;
    case 'C':
       //Do something
    break;
         //etc etc etc
       //Do something
    break;
    case 'B':
       //Do something
    break;
    case 'C':
       //Do something
    break;
         //etc etc etc
  //Do something
void KEYS()
  Kstringnewstate = "";
  for (int KpinNo = 22; KpinNo < 70; KpinNo++){//check for inputs on pins 8 to 70
    KpinStateSTR = String(digitalRead(KpinNo)); //if you change the 8 in the line above ,, also change the 8 in the line below
    KoldpinStateSTR = String(Kstringoldstate.charAt(KpinNo - 22));
    if (KpinStateSTR != KoldpinStateSTR)//yes it's different
      if (KpinNo != 13){ //pin 13 is no good as an input, it can "flutter" unless set up correctly
      if (KpinNo == 22 && KpinStateSTR == "0"){Serial.println ("C01");} //Gear Up
      if (KpinNo == 23 && KpinStateSTR == "0"){Serial.println ("C02");} //Gear Down
      if (KpinNo == 50 && KpinStateSTR == "0"){Serial.println ("B341");} //Auto Throttle On
      if (KpinNo == 51 && KpinStateSTR == "0"){Serial.println ("B340");} //Auto Throttle Off
      if (KpinNo == 52 && KpinStateSTR == "0"){Serial.println ("B301");} //Flight Director On
      if (KpinNo == 53 && KpinStateSTR == "0"){Serial.println ("B300");} //Flight Director Off
      if (KpinNo > 9){//now the keys bit
      Serial.print ("D");
      if (KpinNo < 10) Serial.print ("0");
      Serial.print (KpinNo);
      Serial.println (KpinStateSTR);
      }//end of keys bit
     }//end of its not pin 13
    }//end of yes its different
    Kstringnewstate += KpinStateSTR;
  }//end of 'For' loop
  Kstringoldstate = Kstringnewstate;
}// end of "inputs" void
void ENCODER(){
R =(quad1.position()); //The /2 is to suit the encoder(See my website)
  if (R != Rold) { // checks to see if it different
    (Rdif = (R-Rold));// finds out the difference
   if (Rdif == 1) Serial.println ("A56");// Course decrease
   if (Rdif == -1) Serial.println ("A55"); // Course increase
   Rold = R; // overwrites the old reading with the new one.
  R2 =(quad2.position()/2);
  if (R2 != Rold2) {
    (Rdif2 = (R2-Rold2));
    if (Rdif2 == 1) Serial.println ("B15"); // Speed decrease
    if (Rdif2 == -1) Serial.println ("B16");// Speed increase
    Rold2 = R2;
  R3 =(quad3.position()/2);
  if (R3 != Rold3) {
    (Rdif3 = (R3-Rold3));
    if (Rdif3 == 1) Serial.println ("A57"); // Heading decrease
    if (Rdif3 == -1) Serial.println ("A58"); // Heading increase
    Rold3 = R3;
  R4 =(quad4.position());
  if (R4 != Rold4) {
    (Rdif4 = (R4-Rold4));
    if (Rdif4 == 1) Serial.println ("B11"); // Altitude decrease
    if (Rdif4 == -1) Serial.println ("B12"); // Altitude increase
    Rold4 = R4;
