Haven't been able to figure out how to enter voicemail password(pin) when calling voicemail either via terminal (USB) or arduino. What's the method? Some special AT command? My voicemail keeps saying, "Please enter the voicemail password and then press pound" repeatedly no matter what I type.
Thanks in advance
FONA: how to enter voicemail password
- adafruit2
Re: FONA: how to enter voicemail password
oh you have to send DTMF. hmm we have not added library support for that yet but FONA/SIM800 does support it
can you check out the AT command set data sheet section 3.2.14
AT+VTS="1234567890" will send those dtmf tones
- bprobbins
AT+VTS="1234567890" produces ERROR response when I use putty. I am able to make a call with ATDnnnnnnnnnn;) and AT+VTS=? produces the response +VTS: (0-9,*,#,A,B,C,D),(1-255) so I'm puzzled what is amiss. Any ideas?
- Franklin97355
Try the AT+VTS= without the "" marks.
- bprobbins
Still get ERROR
- bprobbins
Any other ideas about what wrong with sending DMTF strings with AT+VTS= ?? Only single digit or character works with AT+VTS= without quotes (e.g. AT+VTS=7), nothing works with quotes unless I separate each character in the string with a comma (e.g., AT+VTS="7,3,2,1", but in this case T-Mobile voicemail only reacts as if the first digit is sent.
- adafruit_support_rick
Can you just send individual AT+VTS commands?
- bprobbins
No. Voicemail password has to be one complete string. If sent separately, each separate character is rejected as "incorrect password."
- solardude
Search for solutions under the SimCom 900 since its so similar and widely used out there.bprobbins wrote:No. Voicemail password has to be one complete string. If sent separately, each separate character is rejected as "incorrect password."
- bprobbins
I am disappointed I couldn't get the DMTF string function to work. I was finally able to access T-Mobile voicemail via separate DTMF tone commands with RealTerm since it allows sending commands in a file. Couldn't do it manually at the acceptable, not too fast not too slow, speed. Tried various pausing and delays and this is what worked for me:
-Make a text file that is of this structure (assuming a password pin of "9999" and note the double spaced lines and semicolon at end):
at+vts=9
at+vts=9
at+vts=9
at+vts=9
at+vts=#;
-Select this file as the "Dump File to Port"
-Set char delay to 55ms and line delay to 600 and Repeats to 1 (I tried faster combinations that didn't work).
-After you dial your number and get the prompt for your password, press the Send File button.
Hopefully this helps someone else who wants this function. Now I just need to figure out how to do it programmatically.
at+vts=9
at+vts=9
at+vts=9
at+vts=9
at+vts=#;
