And how I change it to km/h?
Thank you!
Thiago Renan da Costa.
#include <Ethernet.h>
#include <SPI.h>
#include "plotly_streaming_ethernet.h"
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3, 2);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO true
boolean usingInterrupt = false;
void useInterrupt(boolean);
// Sign up to plotly here: https://plot.ly
// View your API key and streamtokens here: https://plot.ly/settings
#define nTraces 2
// View your tokens here: https://plot.ly/settings
// Supply as many tokens as data traces
// e.g. if you want to ploty A0 and A1 vs time, supply two tokens
char *tokens[nTraces] = {"sjhdc32erp", "rsv9z5vewu"};
// arguments: username, api key, streaming token, filename
plotly graph = plotly("trenanc", "9c8e5ydnyf", tokens, "Arduino", nTraces);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte my_ip[] = { 189, 6, 135, 133 }; // google will tell you: "public ip address"
void startEthernet(){
Ethernet.begin(mac);
Serial.println("... Initializing ethernet");
if(Ethernet.begin(mac) == 0){
Serial.println("... Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, my_ip);
Serial.println("... Done initializing ethernet");
delay(1000);
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
startEthernet();
graph.fileopt="overwrite"; // See the "Usage" section in https://github.com/plotly/arduino-api for details
bool success;
success = graph.init();
if(!success){while(true){}}
graph.openStream();
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
GPS.sendCommand(PGCMD_ANTENNA);
useInterrupt(true);
delay(1000);
mySerial.println(PMTK_Q_RELEASE);
SIGNAL(TIMER0_COMPA_vect) {
char c = GPS.read();
// if you want to debug, this is a good time to do it!
#ifdef UDR0
if (GPSECHO)
if (c) UDR0 = c;
// writing direct to UDR0 is much much faster than Serial.print
// but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
if (v) {
// Timer0 is already used for millis() - we'll just interrupt somewhere
// in the middle and call the "Compare A" function above
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = true;
} else {
// do not call the interrupt function COMPA anymore
TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
unsigned long x;
int y;
if (! usingInterrupt) {
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA()))
return;
if (timer > millis()) timer = millis();
graph.plot(millis(), GPS.geoidheight, tokens[0]);
graph.plot(millis(), GPS.speed, tokens[1]);
delay(50);
