I followed the instrustions perfectly here:https://learn.adafruit.com/piminer-rasp ... d-assembly. Everything has gone smoothly untill I put in this command "sudo python PiMiner/PiMiner.py &", an error message comes up saying,
"Traceback (most recent call last)
File "PiMiner.py", Line 5, in <module>
from Adafruit_CharLCDPlate import Adafruit_CharLCDPlate
ImportError: No module named Adafruit_CharLCDPlate"
Please help I honestly have know idea how to fix this, I don't code or anything like that. Thank you!
P.S. The green LEDs turn off then come back on after like 30-45 seconds, after this command "sudo nohup ./cgminer-3.1.1/cgminer --config /home/pi/cgminer.conf -S /dev/ttyUSB0 -S /dev/ttyUSB1 >/dev/null 2>&1&"
PiMiner
Re: PiMiner
How did you install your Adafruit RasPi Python library?
Re: PiMiner
The same way it says in the tutorial I guess... I'm new to this so I dont really know alot about it, are you talking about this one? https://github.com/adafruit/Adafruit_Python_CharLCD
Re: PiMiner
Yes. That should be someplace where the PiMiner script can find it.. putting it in the same directory is good.
Re: PiMiner
Well where should I put it? I'm using this https://learn.adafruit.com/adafruit-16x ... y-pi/usage and this part of the tutorial,
sudo apt-get update
sudo apt-get install build-essential python-dev python-smbus python-pip git
sudo pip install RPi.GPIO
git clone https://github.com/adafruit/Adafruit_Python_CharLCD.git
cd Adafruit_Python_CharLCD
sudo python setup.py install
sudo apt-get update
Re: PiMiner
Copy the file Adafruit_CharLCD.py into the same directory as your PiMiner script.
Re: PiMiner
How do i find the directory for Adafruit_CharLCD.py file?
Re: PiMiner
Have you run the command to clone the repo from Github (posted above)?
That creates a directory that contains Adafruit_CharLCD.py.
- exon
Re: PiMiner
Do you have an updated version of PiMiner that will work with https://github.com/adafruit/Adafruit_Python_CharLCD?
Current PiMiner in adafruit repo is pointing towards an import Adafruit_CharLCDPlate which no longer exists in Adafruit_CharLCD under the repo above.
Also, PyMinerDisplay.py gave out the following error:
Help please. Thank you
TypeError: __init__() takes at least 9 arguments (1 given)
- haleyma
Re: PiMiner
Just checking to see if you found a solution, exon? I downloaded the Adafruit_Python_CharLCD file and tried to modify the PiMiner.py file to import Adafruit_CharLCD from that file, but I am getting an ImportError: No module named Adafruit_Python_CharLCD even though the file is in my /home/pi directory. Maybe does it have to be inside the PiMiner directory?
Re: PiMiner
I'm afraid that tutorial is far enough out of date that it needs to be redone from the ground up. It's only useful for historical value at this point.
- haleyma
Re: PiMiner
Thanks, Mike. I appreciate your responding!
- marvelmike
Re: PiMiner
I have the same issue and can't figure out how to update the PiMiner.py script.
Soldering the display was fun and it passes all the display tests provided in the display session perfectly:
"cd examples
sudo python char_lcd_plate.py"
It seems that at some point all the files for PiMiner have been moved by Ada Fruit to a new location, etc. but the paths in the scripts have not been updated to reflect the new names.
Did someone figure it out?
"cd examples
Re: PiMiner
BANNED mining has evolved enough since the tutorial was written that the code only has historical value by now.
- marvelmike
Re: PiMiner
Dear adafruit_support_mike,
are you saying I spent USD 25.00 on a product that you now say has no operating system?
It was clearly advertised as a hardware kit plus code to operate.
https://learn.adafruit.com/adafruit-16x ... i/overview
There is no reference to obsolete and outdated code. On the contrary, there is writing about the kit having been updated to accommodate 4 USB port Raspberries, etc.
And no, BANNED mining has not evolved beyond wanting to see my hash rate, etc.
Please provide updated code so that the product works as advertised until February 28th, 2018, else I will return my purchase at your expense.
Thank you for your understanding.
