Hi guys,
This is my first time making my own 1/8th" stereo male/male audio cables. My understanding of electrical wiring is nonexistent but I'm trying to learn. I have purchased these plugs from Adafruit - https://www.adafruit.com/products/1800
My question is: What kind of wire do I need to get?
I've looked around and seen so many kinds. I can't seem to find an insulated wire with three internally insulated strands. If I used three separate lengths of copper wire to connect the jacks, would my cable work?
And recommendations or explanations would be incredibly helpful. Thanks.
Making Custom 3.5mm M/M Audio Cables. Parts Recommendations?
- lyndon
Re: Making Custom 3.5mm M/M Audio Cables. Parts Recommendati
With the wire in the second link, non-insulated copper goes into the ground sleeve, right?
Once I find a 2-conductor shielded wire with the right diameter (looking to sleeve for aesthetics), I should be good to go. Thanks for letting me know what to search for.
- lyndon
What's wrong with the one I linked to? It should be exactly what you need. Yes, the shield is ground.
