I purchased a type A USB shell connector (product 1387) and I think I can glean how the green, red, white, and black internal wires connect from this diagram and the old plug end I cut off. but I'm wondering if I need to connect the shield wire somewhere. I don't just need USB power, I need to communicate with an Arduino. And I needed the connector, because I will be running the USB cable through an enclosure with cable gland (reference image attached). Thanks.
USb type A shell – need connection help
- Unio
- wire_ref_sm.jpg (75.94 KiB) Viewed 648 times
- Franklin97355
Re: USb type A shell – need connection help
The shield wire can be connected to the shell of the USB connector. It is not used for communications but noise immunity.
- Unio
Great! Thanks so much!
