I successfully followed the onion pi and ad blocking AP tutorials. Now i tried to make a tor proxy that blocks ad, and nothing works. Do you have an idea why? And is it possible to make it work ? I'm such a noob so i'm quite lost. And to get it better, english is not my language. :-D
Onion pi ad blocking AP
- adafruit_support_rick
Re: Onion pi ad blocking AP
[moved to General Project Help]
Any suggestion? Anyone?
There are a lot of moving pieces there, so we'll need more detail than "it doesn't work."
Can you make TOR connections through the WAP for non-ad-serving domains?
No i can't connect to the AP anymore. I see it in my wifi settings, and when i try to connect, it fails. It was working well with tor without ad blocking, and with ad blocking without tor.
That sounds like a conflict between the TOR proxy and dnsmasq (used for the ad blocker).
What do you have in the file /etc/tor/torrc ?
## Configuration file for a typical Tor user
## Last updated 22 April 2012 for Tor 0.2.3.14-alpha.
## (may or may not work for much older or much newer versions of Tor.)
## Lines that begin with "## " try to explain what's going on. Lines
## that begin with just "#" are disabled commands: you can enable them
## by removing the "#" symbol.
## See 'man tor', or https://www.torproject.org/docs/tor-manual.html,
## for more options you can use in this file.
## Tor will look for this file in various places based on your platform:
## https://www.torproject.org/docs/faq#torrc
Log notice file /var/log/tor/notices.log
VirtualAddrNetwork 10.192.0.0/10
AutomapHostsSuffixes .onion,.exit
AutomapHostsOnResolve 1
TransPort 9040
TransListenAddress 192.168.42.1
DNSPort 53
DNSListenAddress 192.168.42.1
StrictExitNodes 1
ExitNodes {US},{GB}
## Tor opens a socks proxy on port 9050 by default -- even if you don't
## configure one below. Set "SocksPort 0" if you plan to run Tor only
## as a relay, and not make any local application connections yourself.
#SocksPort 9050 # Default: Bind to localhost:9050 for local connections.
#SocksPort 192.168.0.1:9100 # Bind to this adddress:port too.
## Entry policies to allow/deny SOCKS requests based on IP address.
## First entry that matches wins. If no SocksPolicy is set, we accept
## all (and only) requests that reach a SocksPort. Untrusted users who
## can access your SocksPort may be able to learn about the connections
## you make.
#SocksPolicy accept 192.168.0.0/16
#SocksPolicy reject *
## Logs go to stdout at level "notice" unless redirected by something
## else, like one of the below lines. You can have as many Log lines as
## you want.
## We advise using "notice" in most cases, since anything more verbose
## may provide sensitive information to an attacker who obtains the logs.
## Send all messages of level 'notice' or higher to /var/log/tor/notices.log
#Log notice file /var/log/tor/notices.log
## Send every possible message to /var/log/tor/debug.log
#Log debug file /var/log/tor/debug.log
## Use the system log instead of Tor's logfiles
#Log notice syslog
## To send all messages to stderr:
#Log debug stderr
## Uncomment this to start the process in the background... or use
## --runasdaemon 1 on the command line. This is ignored on Windows;
## see the FAQ entry if you want Tor to run as an NT service.
#RunAsDaemon 1
## The directory for keeping all the keys/etc. By default, we store
## things in $HOME/.tor on Unix, and in Application Data\tor on Windows.
#DataDirectory /var/lib/tor
## The port on which Tor will listen for local connections from Tor
## controller applications, as documented in control-spec.txt.
#ControlPort 9051
## If you enable the controlport, be sure to enable one of these
## authentication methods, to prevent BANNED from accessing it.
#HashedControlPassword 16:872860B76453A77D60CA2BB8C1A7042072093276A3D701AD684053EC4C
#CookieAuthentication 1
############### This section is just for location-hidden services ###
## Once you have configured a hidden service, you can look at the
## contents of the file ".../hidden_service/hostname" for the address
## to tell people.
## HiddenServicePort x y:z says to redirect requests on port x to the
## address y:z.
#HiddenServiceDir /var/lib/tor/hidden_service/
#HiddenServicePort 80 127.0.0.1:80
#HiddenServiceDir /var/lib/tor/other_hidden_service/
#HiddenServicePort 22 127.0.0.1:22
################ This section is just for relays #####################
## See https://www.torproject.org/docs/tor-doc-relay for details.
## Required: what port to advertise for incoming Tor connections.
#ORPort 9001
## If you want to listen on a port other than the one advertised in
## ORPort (e.g. to advertise 443 but bind to 9090), you can do it as
## follows. You'll need to do ipchains or other port forwarding
## yourself to make this work.
#ORPort 443 NoListen
#ORPort 127.0.0.1:9090 NoAdvertise
## The IP address or full DNS name for incoming connections to your
## relay. Leave commented out and Tor will guess.
#Address noname.example.com
## If you have multiple network interfaces, you can specify one for
## outgoing traffic to use.
# OutboundBindAddress 10.0.0.5
## A handle for your relay, so people don't have to refer to it by key.
#Nickname ididnteditheconfig
## Define these to limit how much relayed traffic you will allow. Your
## own traffic is still unthrottled. Note that RelayBandwidthRate must
## be at least 20 KB.
## Note that units for these config options are bytes per second, not bits
## per second, and that prefixes are binary prefixes, i.e. 2^10, 2^20, etc.
#RelayBandwidthRate 100 KB # Throttle traffic to 100KB/s (800Kbps)
#RelayBandwidthBurst 200 KB # But allow bursts up to 200KB/s (1600Kbps)
## Use these to restrict the maximum traffic per day, week, or month.
## Note that this threshold applies separately to sent and received bytes,
## not to their sum: setting "4 GB" may allow up to 8 GB total before
## hibernating.
## Set a maximum of 4 gigabytes each way per period.
#AccountingMax 4 GB
## Each period starts daily at midnight (AccountingMax is per day)
#AccountingStart day 00:00
## Each period starts on the 3rd of the month at 15:00 (AccountingMax
## is per month)
#AccountingStart month 3 15:00
## Contact info to be published in the directory, so we can contact you
## if your relay is misconfigured or something else goes wrong. Google
## indexes this, so spammers might also collect it.
#ContactInfo Random Person <nobody AT example dot com>
## You might also include your PGP or GPG fingerprint if you have one:
#ContactInfo 0xFFFFFFFF Random Person <nobody AT example dot com>
## Uncomment this to mirror directory information for others. Please do
## if you have enough bandwidth.
#DirPort 9030 # what port to advertise for directory connections
## DirPort (e.g. to advertise 80 but bind to 9091), you can do it as
## follows. below too. You'll need to do ipchains or other port
## forwarding yourself to make this work.
#DirPort 80 NoListen
#DirPort 127.0.0.1:9091 NoAdvertise
## Uncomment to return an arbitrary blob of html on your DirPort. Now you
## can explain what Tor is if anybody wonders why your IP address is
## contacting them. See contrib/tor-exit-notice.html in Tor's source
## distribution for a sample.
#DirPortFrontPage /etc/tor/tor-exit-notice.html
## Uncomment this if you run more than one Tor relay, and add the identity
## key fingerprint of each Tor relay you control, even if they're on
## different networks. You declare it here so Tor clients can avoid
## using more than one of your relays in a single circuit. See
## https://www.torproject.org/docs/faq#MultipleRelays
## However, you should never include a bridge's fingerprint here, as it would
## break its concealability and potentionally reveal its IP/TCP address.
#MyFamily $keyid,$keyid,...
## A comma-separated list of exit policies. They're considered first
## to last, and the first match wins. If you want to _replace_
## the default exit policy, end this with either a reject *:* or an
## accept *:*. Otherwise, you're _augmenting_ (prepending to) the
## default exit policy. Leave commented to just use the default, which is
## described in the man page or at
## https://www.torproject.org/documentation.html
## Look at https://www.torproject.org/faq-abuse.html#TypicalAbuses
## for issues you might encounter if you use the default exit policy.
## If certain IPs and ports are blocked externally, e.g. by your firewall,
## you should update your exit policy to reflect this -- otherwise Tor
## users will be told that those destinations are down.
## For security, by default Tor rejects connections to private (local)
## networks, including to your public IP address. See the man page entry
## for ExitPolicyRejectPrivate if you want to allow "exit enclaving".
#ExitPolicy accept *:6660-6667,reject *:* # allow irc ports but no more
#ExitPolicy accept *:119 # accept nntp as well as default exit policy
#ExitPolicy reject *:* # no exits allowed
## Bridge relays (or "bridges") are Tor relays that aren't listed in the
## main directory. Since there is no complete public list of them, even an
## ISP that filters connections to all the known Tor relays probably
## won't be able to block all the bridges. Also, websites won't treat you
## differently because they won't know you're running Tor. If you can
## be a real relay, please do; but if not, be a bridge!
#BridgeRelay 1
## By default, Tor will advertise your bridge to users through various
## mechanisms like https://bridges.torproject.org/. If you want to run
## a private bridge, for example because you'll give out your bridge
## address manually to your friends, uncomment this line:
#PublishServerDescriptor 0
Okay, nothing out of the ordinary there.
Do you see any errors in /var/log/messages from either dnsmasq or the TOR proxy?
Aug 21 06:25:08 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="2065" x-info="http://www.rs$
Aug 21 18:25:17 raspberrypi shutdown[2794]: shutting down for system reboot
Aug 21 18:25:37 raspberrypi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Aug 21 18:25:37 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="2063" x-info="http://www.rs$
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Initializing cgroup subsys cpu
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Initializing cgroup subsys cpuacct
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Linux version 3.12.22+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 $
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00$
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instructio$
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Machine: BCM2708
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] cma: CMA: reserved 8 MiB at 1b800000
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Memory policy: ECC disabled, Data cache writeback
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages:$
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2$
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Memory: 439664K/458752K available (4376K kernel code, 238K rwdata, 1$
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Virtual kernel memory layout:
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] .text : 0xc0008000 - 0xc059d54c (5718 kB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] .init : 0xc059e000 - 0xc05c1ee4 ( 144 kB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] .data : 0xc05c2000 - 0xc05fd900 ( 239 kB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] .bss : 0xc05fd90c - 0xc06ad0f8 ( 702 kB)
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] NR_IRQS:394
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294$
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Switching to timer-based delay loop
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] Console: colour dummy device 80x30
Aug 21 18:25:37 raspberrypi kernel: [ 0.000000] console [tty1] enabled
Aug 21 18:25:37 raspberrypi kernel: [ 0.001264] Calibrating delay loop (skipped), value calculated using timer frequ$
Aug 21 18:25:37 raspberrypi kernel: [ 0.001325] pid_max: default: 32768 minimum: 301
Aug 21 18:25:37 raspberrypi kernel: [ 0.001822] Mount-cache hash table entries: 512
Aug 21 18:25:37 raspberrypi kernel: [ 0.002655] Initializing cgroup subsys memory
Aug 21 18:25:37 raspberrypi kernel: [ 0.002764] Initializing cgroup subsys devices
Aug 21 18:25:37 raspberrypi kernel: [ 0.002803] Initializing cgroup subsys freezer
Aug 21 18:25:37 raspberrypi kernel: [ 0.002836] Initializing cgroup subsys blkio
Aug 21 18:25:37 raspberrypi kernel: [ 0.002979] CPU: Testing write buffer coherency: ok
Aug 21 18:25:37 raspberrypi kernel: [ 0.003440] Setting up static identity map for 0xc0427670 - 0xc04276cc
Aug 21 18:25:37 raspberrypi kernel: [ 0.005357] devtmpfs: initialized
Aug 21 18:25:37 raspberrypi kernel: [ 0.022083] VFP support v0.3: implementor 41 architecture 1 part 20 variant b re$
Aug 21 18:25:37 raspberrypi kernel: [ 0.023674] NET: Registered protocol family 16
Aug 21 18:25:37 raspberrypi kernel: [ 0.029070] DMA: preallocated 4096 KiB pool for atomic coherent allocations
Aug 21 18:25:37 raspberrypi kernel: [ 0.029762] cpuidle: using governor ladder
Aug 21 18:25:37 raspberrypi kernel: [ 0.029809] cpuidle: using governor menu
Aug 21 18:25:37 raspberrypi kernel: [ 0.030408] bcm2708.uart_clock = 0
Aug 21 18:25:37 raspberrypi kernel: [ 0.032239] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Aug 21 18:25:37 raspberrypi kernel: [ 0.032294] hw-breakpoint: maximum watchpoint size is 4 bytes.
Aug 21 18:25:37 raspberrypi kernel: [ 0.032332] mailbox: Broadcom VideoCore Mailbox driver
Aug 21 18:25:37 raspberrypi kernel: [ 0.032432] bcm2708_vcio: mailbox at f200b880
Aug 21 18:25:37 raspberrypi kernel: [ 0.032539] bcm_power: Broadcom power driver
Aug 21 18:25:37 raspberrypi kernel: [ 0.032577] bcm_power_open() -> 0
Aug 21 18:25:37 raspberrypi kernel: [ 0.032603] bcm_power_request(0, 8)
Aug 21 18:25:37 raspberrypi kernel: [ 0.533325] bcm_mailbox_read -> 00000080, 0
Aug 21 18:25:37 raspberrypi kernel: [ 0.533364] bcm_power_request -> 0
Aug 21 18:25:37 raspberrypi kernel: [ 0.533595] Serial: AMBA PL011 UART driver
Aug 21 18:25:37 raspberrypi kernel: [ 0.533764] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL$
Aug 21 18:25:37 raspberrypi kernel: [ 0.891915] console [ttyAMA0] enabled
Aug 21 18:25:37 raspberrypi kernel: [ 0.918799] bio: create slab <bio-0> at 0
Aug 21 18:25:37 raspberrypi kernel: [ 0.924311] SCSI subsystem initialized
Aug 21 18:25:37 raspberrypi kernel: [ 0.928310] usbcore: registered new interface driver usbfs
Aug 21 18:25:37 raspberrypi kernel: [ 0.934015] usbcore: registered new interface driver hub
Aug 21 18:25:37 raspberrypi kernel: [ 0.939579] usbcore: registered new device driver usb
Aug 21 18:25:37 raspberrypi kernel: [ 0.946213] Switched to clocksource stc
Aug 21 18:25:37 raspberrypi kernel: [ 0.950477] FS-Cache: Loaded
Aug 21 18:25:37 raspberrypi kernel: [ 0.953632] CacheFiles: Loaded
Aug 21 18:25:37 raspberrypi kernel: [ 0.969389] NET: Registered protocol family 2
Aug 21 18:25:37 raspberrypi kernel: [ 0.974890] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 0.982300] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 0.988870] TCP: Hash tables configured (established 4096 bind 4096)
Aug 21 18:25:37 raspberrypi kernel: [ 0.995321] TCP: reno registered
Aug 21 18:25:37 raspberrypi kernel: [ 0.998618] UDP hash table entries: 256 (order: 0, 4096 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 1.004490] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 1.011248] NET: Registered protocol family 1
Aug 21 18:25:37 raspberrypi kernel: [ 1.016179] RPC: Registered named UNIX socket transport module.
Aug 21 18:25:37 raspberrypi kernel: [ 1.022236] RPC: Registered udp transport module.
Aug 21 18:25:37 raspberrypi kernel: [ 1.026995] RPC: Registered tcp transport module.
Aug 21 18:25:37 raspberrypi kernel: [ 1.031714] RPC: Registered tcp NFSv4.1 backchannel transport module.
Aug 21 18:25:37 raspberrypi kernel: [ 1.039093] bcm2708_dma: DMA manager at f2007000
Aug 21 18:25:37 raspberrypi kernel: [ 1.043831] bcm2708_gpio: bcm2708_gpio_probe c05cfed0
Aug 21 18:25:37 raspberrypi kernel: [ 1.049398] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000$
Aug 21 18:25:37 raspberrypi kernel: [ 1.059008] audit: initializing netlink socket (disabled)
Aug 21 18:25:37 raspberrypi kernel: [ 1.064512] type=2000 audit(0.910:1): initialized
Aug 21 18:25:37 raspberrypi kernel: [ 1.231149] VFS: Disk quotas dquot_6.5.2
Aug 21 18:25:37 raspberrypi kernel: [ 1.235421] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 21 18:25:37 raspberrypi kernel: [ 1.244438] FS-Cache: Netfs 'nfs' registered for caching
Aug 21 18:25:37 raspberrypi kernel: [ 1.251404] NFS: Registering the id_resolver key type
Aug 21 18:25:37 raspberrypi kernel: [ 1.256696] Key type id_resolver registered
Aug 21 18:25:37 raspberrypi kernel: [ 1.260903] Key type id_legacy registered
Aug 21 18:25:37 raspberrypi kernel: [ 1.265668] msgmni has been set to 874
Aug 21 18:25:37 raspberrypi kernel: [ 1.271482] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Aug 21 18:25:37 raspberrypi kernel: [ 1.279343] io scheduler noop registered
Aug 21 18:25:37 raspberrypi kernel: [ 1.283298] io scheduler deadline registered (default)
Aug 21 18:25:37 raspberrypi kernel: [ 1.288891] io scheduler cfq registered
Aug 21 18:25:37 raspberrypi kernel: [ 1.294056] BCM2708FB: allocated DMA memory 5bc00000
Aug 21 18:25:37 raspberrypi kernel: [ 1.299241] BCM2708FB: allocated DMA channel 0 @ f2007000
Aug 21 18:25:37 raspberrypi kernel: [ 1.315222] Console: switching to colour frame buffer device 82x26
Aug 21 18:25:37 raspberrypi kernel: [ 1.325333] uart-pl011 dev:f1: no DMA platform data
Aug 21 18:25:37 raspberrypi kernel: [ 1.332435] vc-cma: Videocore CMA driver
Aug 21 18:25:37 raspberrypi kernel: [ 1.337882] vc-cma: vc_cma_base = 0x00000000
Aug 21 18:25:37 raspberrypi kernel: [ 1.343892] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
Aug 21 18:25:37 raspberrypi kernel: [ 1.350626] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
Aug 21 18:25:37 raspberrypi kernel: [ 1.366645] brd: module loaded
Aug 21 18:25:37 raspberrypi kernel: [ 1.376343] loop: module loaded
Aug 21 18:25:37 raspberrypi kernel: [ 1.381034] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
Aug 21 18:25:37 raspberrypi kernel: [ 1.390200] Loading iSCSI transport class v2.0-870.
Aug 21 18:25:37 raspberrypi kernel: [ 1.397684] usbcore: registered new interface driver smsc95xx
Aug 21 18:25:37 raspberrypi kernel: [ 1.405188] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Aug 21 18:25:37 raspberrypi kernel: [ 1.612499] Core Release: 2.80a
Aug 21 18:25:37 raspberrypi kernel: [ 1.617037] Setting default values for core params
Aug 21 18:25:37 raspberrypi kernel: [ 1.623099] Finished setting default values for core params
Aug 21 18:25:37 raspberrypi kernel: [ 1.829975] Using Buffer DMA mode
Aug 21 18:25:37 raspberrypi kernel: [ 1.834517] Periodic Transfer Interrupt Enhancement - disabled
Aug 21 18:25:37 raspberrypi kernel: [ 1.841622] Multiprocessor Interrupt Enhancement - disabled
Aug 21 18:25:37 raspberrypi kernel: [ 1.848498] OTG VER PARAM: 0, OTG VER FLAG: 0
Aug 21 18:25:37 raspberrypi kernel: [ 1.854109] Dedicated Tx FIFOs mode
Aug 21 18:25:37 raspberrypi kernel: [ 1.859232] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc140$
Aug 21 18:25:37 raspberrypi kernel: [ 1.871728] FIQ FSM acceleration enabled for :
Aug 21 18:25:37 raspberrypi kernel: [ 1.871728] Non-periodic Split Transactions
Aug 21 18:25:37 raspberrypi kernel: [ 1.871728] Periodic Split Transactions
Aug 21 18:25:37 raspberrypi kernel: [ 1.871728] High-Speed Isochronous Endpoints
Aug 21 18:25:37 raspberrypi kernel: [ 1.893693] WARN::hcd_init:473: FIQ at 0xc03080cc
Aug 21 18:25:37 raspberrypi kernel: [ 1.899870] WARN::hcd_init:474: FIQ ASM at 0xc0308348 length 36
Aug 21 18:25:37 raspberrypi kernel: [ 1.907215] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
Aug 21 18:25:37 raspberrypi kernel: [ 1.914215] dwc_otg bcm2708_usb: DWC OTG Controller
Aug 21 18:25:37 raspberrypi kernel: [ 1.920463] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Aug 21 18:25:37 raspberrypi kernel: [ 1.929122] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
Aug 21 18:25:37 raspberrypi kernel: [ 1.935934] Init: Port Power? op_state=1
Aug 21 18:25:37 raspberrypi kernel: [ 1.941170] Init: Power Port (0)
Aug 21 18:25:37 raspberrypi kernel: [ 1.945935] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Aug 21 18:25:37 raspberrypi kernel: [ 1.954091] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 21 18:25:37 raspberrypi kernel: [ 1.962667] usb usb1: Product: DWC OTG Controller
Aug 21 18:25:37 raspberrypi kernel: [ 1.968688] usb usb1: Manufacturer: Linux 3.12.22+ dwc_otg_hcd
Aug 21 18:25:37 raspberrypi kernel: [ 1.975809] usb usb1: SerialNumber: bcm2708_usb
Aug 21 18:25:37 raspberrypi kernel: [ 1.982479] hub 1-0:1.0: USB hub found
Aug 21 18:25:37 raspberrypi kernel: [ 1.987693] hub 1-0:1.0: 1 port detected
Aug 21 18:25:37 raspberrypi kernel: [ 1.993817] usbcore: registered new interface driver usb-storage
Aug 21 18:25:37 raspberrypi kernel: [ 2.001549] mousedev: PS/2 mouse device common for all mice
Aug 21 18:25:37 raspberrypi kernel: [ 2.009134] bcm2835-cpufreq: min=700000 max=700000 cur=700000
Aug 21 18:25:37 raspberrypi kernel: [ 2.016365] bcm2835-cpufreq: switching to governor powersave
Aug 21 18:25:37 raspberrypi kernel: [ 2.023284] bcm2835-cpufreq: switching to governor powersave
Aug 21 18:25:37 raspberrypi kernel: [ 2.030315] sdhci: Secure Digital Host Controller Interface driver
Aug 21 18:25:37 raspberrypi kernel: [ 2.037778] sdhci: Copyright(c) Pierre Ossman
Aug 21 18:25:37 raspberrypi kernel: [ 2.043443] sdhci: Enable low-latency mode
Aug 21 18:25:37 raspberrypi kernel: [ 2.086429] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's$
Aug 21 18:25:37 raspberrypi kernel: [ 2.097055] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
Aug 21 18:25:37 raspberrypi kernel: [ 2.104291] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 21 18:25:37 raspberrypi kernel: [ 2.111467] ledtrig-cpu: registered to indicate activity on CPUs
Aug 21 18:25:37 raspberrypi kernel: [ 2.121112] hidraw: raw HID events driver (C) Jiri Kosina
Aug 21 18:25:37 raspberrypi kernel: [ 2.135471] usbcore: registered new interface driver usbhid
Aug 21 18:25:37 raspberrypi kernel: [ 2.142566] usbhid: USB HID core driver
Aug 21 18:25:37 raspberrypi kernel: [ 2.152475] TCP: cubic registered
Aug 21 18:25:37 raspberrypi kernel: [ 2.159274] Initializing XFRM netlink socket
Aug 21 18:25:37 raspberrypi kernel: [ 2.167027] NET: Registered protocol family 17
Aug 21 18:25:37 raspberrypi kernel: [ 2.173056] Key type dns_resolver registered
Aug 21 18:25:37 raspberrypi kernel: [ 2.186478] Indeed it is in host mode hprt0 = 00021501
Aug 21 18:25:37 raspberrypi kernel: [ 2.196459] registered taskstats version 1
Aug 21 18:25:37 raspberrypi kernel: [ 2.206919] Waiting for root device /dev/mmcblk0p2...
Aug 21 18:25:37 raspberrypi kernel: [ 2.258641] mmc0: read SD Status register (SSR) after 3 attempts
Aug 21 18:25:37 raspberrypi kernel: [ 2.286325] mmc0: new high speed SDHC card at address 0007
Aug 21 18:25:37 raspberrypi kernel: [ 2.294922] mmcblk0: mmc0:0007 SD32G 29.8 GiB
Aug 21 18:25:37 raspberrypi kernel: [ 2.304512] mmcblk0: p1 p2
Aug 21 18:25:37 raspberrypi kernel: [ 2.361053] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts$
Aug 21 18:25:37 raspberrypi kernel: [ 2.372071] VFS: Mounted root (ext4 filesystem) on device 179:2.
Aug 21 18:25:37 raspberrypi kernel: [ 2.382214] devtmpfs: mounted
Aug 21 18:25:37 raspberrypi kernel: [ 2.387129] Freeing unused kernel memory: 140K (c059e000 - c05c1000)
Aug 21 18:25:37 raspberrypi kernel: [ 2.406382] usb 1-1: new high-speed USB device number 2 using dwc_otg
Aug 21 18:25:37 raspberrypi kernel: [ 2.414477] Indeed it is in host mode hprt0 = 00001101
Aug 21 18:25:37 raspberrypi kernel: [ 2.616655] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Aug 21 18:25:37 raspberrypi kernel: [ 2.625693] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 21 18:25:37 raspberrypi kernel: [ 2.635235] hub 1-1:1.0: USB hub found
Aug 21 18:25:37 raspberrypi kernel: [ 2.640673] hub 1-1:1.0: 3 ports detected
Aug 21 18:25:37 raspberrypi kernel: [ 2.926489] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Aug 21 18:25:37 raspberrypi kernel: [ 3.036753] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Aug 21 18:25:37 raspberrypi kernel: [ 3.045291] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 21 18:25:37 raspberrypi kernel: [ 3.057750] smsc95xx v1.0.4
Aug 21 18:25:37 raspberrypi kernel: [ 3.121209] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1,$
Aug 21 18:25:37 raspberrypi kernel: [ 3.236570] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Aug 21 18:25:37 raspberrypi kernel: [ 3.368372] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8176
Aug 21 18:25:37 raspberrypi kernel: [ 3.377274] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 21 18:25:37 raspberrypi kernel: [ 3.386315] usb 1-1.2: Product: 802.11n WLAN Adapter
Aug 21 18:25:37 raspberrypi kernel: [ 3.392845] usb 1-1.2: Manufacturer: Realtek
Aug 21 18:25:37 raspberrypi kernel: [ 3.398896] usb 1-1.2: SerialNumber: 00e04c000001
Aug 21 18:25:37 raspberrypi kernel: [ 6.307567] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
Aug 21 18:25:37 raspberrypi kernel: [ 7.573351] usbcore: registered new interface driver rtl8192cu
Aug 21 18:25:37 raspberrypi kernel: [ 12.809668] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Aug 21 18:25:37 raspberrypi kernel: [ 13.344328] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Aug 21 18:25:37 raspberrypi kernel: [ 20.226160] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may$
Aug 21 18:25:37 raspberrypi kernel: [ 23.300057] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Aug 21 18:25:37 raspberrypi kernel: [ 24.278891] ip_tables: (C) 2000-2006 Netfilter Core Team
Aug 21 18:25:37 raspberrypi kernel: [ 24.326429] nf_conntrack version 0.5.0 (6999 buckets, 27996 max)
Aug 21 18:25:37 raspberrypi kernel: [ 24.873155] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
Aug 21 18:25:40 raspberrypi kernel: [ 30.779020] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:1023$
pi@raspberrypi ~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:a4:49:9b
inet adr:192.168.0.24 Bcast:192.168.0.255 Masque:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:719 errors:0 dropped:0 overruns:0 frame:0
TX packets:494 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:1000
RX bytes:56509 (55.1 KiB) TX bytes:153894 (150.2 KiB)
lo Link encap:Boucle locale
inet adr:127.0.0.1 Masque:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 00:0f:13:56:0e:52
RX packets:195 errors:0 dropped:64 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:44710 (43.6 KiB) TX bytes:2526 (2.4 KiB)
The output from `ifconfig` says your wireless adaptor hasn't been assigned an IP address. What do you have in /etc/network/interfaces ?
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet static
adress 192.168.42.1
network 255.255.255.0
up iptables-restore < /etc/iptables.ipv4.nat
Try adding:
after
The 'auto' directive tells the OS to configure wlan0 any time it gets an `ifup` command that doesn't specify an interface (which is what happens during the boot process). Without it, you have to tell the OS to configure wlan0 explicitly.
auto wlan0
allow-hotplug wlan0
