teensy with retropie
pandadesh
Post by pandadesh »
the topic is basically my question. how do i use it? i have a 3.1 and a 2.0 teensy so can someone tell how to use any of them with retropie?
pandadesh
Re: teensy with retropie
Post by pandadesh »
hello? can someone clear my doubt?
pburgess
Post by pburgess »
Lots of info on the PJRC web site. See the "Using Pushbuttons" section on this page, it's exactly the sort of thing you're after:
https://www.pjrc.com/teensy/td_keyboard.html
Also have a look through the Projects page there, might be some additional examples/inspiration.
pandadesh
Post by pandadesh »
pburgess wrote:Lots of info on the PJRC web site. See the "Using Pushbuttons" section on this page, it's exactly the sort of thing you're after:
i know how to use it in windoze and mac and it works flawlessly in joystick form. i want to use it with retropie, but it does not come up as a usb joystick. how do i make it a usb joystick that is compatible with retropie?
pburgess
Post by pburgess »
Does Retropie support keyboard input? Make the Teensy emulate a keyboard. Or maybe this is relevant:
https://www.pjrc.com/teensy/td_joystick.html
pandadesh
Post by pandadesh »
pburgess wrote:Does Retropie support keyboard input? Make the Teensy emulate a keyboard. Or maybe this is relevant:
i know abt the examples on the prjc site
whenever i connect my teensy to the pi it just doesn't read it. i guess there must be some sort of code or something to make it work.
if it doesn't work then i guess i will use a hummingboard and ubuntu
bennyboom
Post by bennyboom »
Hello
I have used this tutorial to connect my teensy on retropie
http://www.alfersoft.com.ar/blog/2014/0 ... eensy-3-0/
But control are not good , up stick command the left direction and other problem like this.
I don't know how to fix this, into retropie or maybe into teensy sketch with input button key code.
if it can help
