I have a question about the Adding arcade buttons tutorial.
If I read it well, the buttons are connected to 1 GPIO et to the GND, correct ?
In every other tutorials, how-to... buttons needs to be connected to the 3.3V (with 1/2 resistors), to GPIO and to GND.. How the pi can read an "unplugged" button ?
Thanks for the help
Retrogaming with RPI - Buttons
- egutting
Re: Retrogaming with RPI - Buttons
I'm not completely sure (pburgess probably can give you a better answer), but I would think that the Pi may be looking for a falling interrupt and attaching an action to it. Kind of similar to this blog post:
http://www.adafruit.com/blog/2013/03/29 ... io-part-3/
The RasPi's GPIO pins have built-in pull-up resistors. If you tell the microprocessor to use the pull-ups, you don't need an external resistor.
- Adisma
Thanks.
But in this tuto buttons are connected to 3.3v.
In adafruit arcade tuto they're only connected to gpio and ground..
Like I said: the RasPi's GPIO pins have built-in pull-up resistors.
When you enable the pull-up, the chip makes the connection between the GPIO pin and 3.3v internally.
- Adisma
Great ! Thanks :)
Ok, they are ^^Do you know if the "retrogame" utility available in the tuto enables the pull-up resistor ? Or, is it a way to enable them by default ?
