How do I change TCS34725 address?
- warren631
Hi Guys. I need to connect two TCS34725 color sensors to a Mega. How do I change the I2C address in the TCS34725's so I can have two different I2C addresses. I guess I will have to also change the Adafruit TCS34725 library to a variable address. Thanks for any help.
Re: How do I change TCS34725 address?
The device has a fixed address. If you want to run 2, you would need to use "Softi2c".
http://playground.arduino.cc/Main/SoftwareI2CLibrary
- warren631
Thanks Support. Even with a software driver I don't understand how I can communicate with two devices with the same address. Should use "Softi2c" to create two separate I2C busses from the Mega? How are they separated in code if both addresses are the same. Are there any code examples? I already have one I2C bus connected to a compass using the Wires library. A fixed address seems very limiting. Seems to be defeating the purpose of the I2C bus system.
You can use the hardware i2c bus for one of them, and a softi2c bus for the other. It is a shame that some manufacturers don't provide addressability for their i2c devices.
- warren631
Another solution I found is to use an I2C multiplexer like this: http://www.dsscircuits.com/index.php/i2c-multiplexer
That is certainly a valid solution. But it still requires additional address pins, and code to select between them.
