WS2812S 5050 RGB LED with Integrated Driver Chip - 10 Pack
I want to create a LED Matrix with 1000 of these and don't know what to use to drive them at a decent refresh rate. If possible id like to stream video to them and also program each led individually.
Any input would be greatly appreciated.
1000 LED matrix, HELP!!!
- adafruit_support_rick
Re: 1000 LED matrix, HELP!!!
The WS2812S isn't a good choice for video. We have a tutorial on video using conventional LED matrices:
https://learn.adafruit.com/adafruit-diy-led-video-wall
For individually programming 1000 WS2812's, you would use an Arduino Mega or Arduino Due. Or, you could look into the FadeCandy:
https://www.adafruit.com/product/1689
- Muggerrudd
i can not use a standard prefab panel due to the screen will be in a dome shape and will be bent in several directions. this is why i am looking at using individual leds.
Video will require specialized hardware, which won't be compatible with the WS2812.
However, there's no reason why you can't use the WS2812 with non-video sources in your project
