Newbie question. I have a project where I'm wiring together 12 LEDs for a costume. That seems like a lot of wires to splice and solder to the 6V battery pack.
Is there a tutorial on how to do that, or is there another method like breaking them up into groups of 4 or some sort of connector like a wire harness that I should use?
Splicing multiple (10+) wires together
Re: Splicing multiple (10+) wires together
There are things like solderless splices, terminal blocks and power distribution bus bars. But these can be kind of bulky for a costume Depending on how your leds are distributed, you might consider branching off in groups of 2 or 3 to avoid having one massive bulky splice.
- Franklin97355
In the past I've bought copper tube from the hobby store big enough to take the wires and soldered them in with one wire coming out the other end and adding heat shrink over the splice.
- pvonelling
Thanks for your ideas. Off to solder it all together tonight. Will let you know how it goes.
- pvonelling
Hey, put it all together last night, and even though I was hooking up and soldering until 2AM, it went great! LEDs are glowing and it all came together.
I had 12 LEDs so just made 4 groups of three and then hooked up each group to the battery holder and switch. Worked like a charm.
Thanks for sharing your knowledge. Much, much appreciated!
