https://www.adafruit.com/products/938
https://www.adafruit.com/products/1697
I'm trying to get both the bluetooth module and display to play nicely. I'm using a Pro Trinket (5v) for this. I have had both the bluetooth module and display working (independently, never together).
I tried previously with both using SPI, though currently the display is set up for I2C.
I moved the display to I2C hoping I could avoid what seemed a less than straight forward process of learning SPI management.
I started with working bluetooth via the callbackEcho demo (with serial message stuff removed, since I won't see it anyway on the Pro Trinket). I tossed an LED on pin 4 that gives me a visual when there is incoming data.
I then start adding in the dependencies for the display, which don't seem to mess anything up, but the moment I try to initialize the display, I get blinking pixels on the display and a flashing red light on pin 13 (I feel like that LED sharing a pin with the BTLE module is probably not the greatest).
I'm attaching a Fritzing breadboard image just to show my wiring (minus the LED, which is just a resistor from pin 4, to the led, to ground), and my latest run through with a sketch from scratch showing the last line I tossed in that just stops it in its tracks. I have taken it further (aka combining to entire working sketches), though those never work either.
Any assistance is appreciated.
#include <SPI.h>
#include "Adafruit_BLE_UART.h"
// ADDED FOR DISPLAY
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define ADAFRUITBLE_REQ 10
#define ADAFRUITBLE_RDY 3
#define ADAFRUITBLE_RST 9
#define OLED_RESET 8
Adafruit_SSD1306 display(OLED_RESET);
Adafruit_BLE_UART uart = Adafruit_BLE_UART(ADAFRUITBLE_REQ, ADAFRUITBLE_RDY, ADAFRUITBLE_RST);
int led = 4;
This function is called whenever select ACI events happen
void aciCallback(aci_evt_opcode_t event)
switch(event)
case ACI_EVT_DEVICE_STARTED:
Serial.println(F("Advertising started"));
break;
case ACI_EVT_CONNECTED:
Serial.println(F("Connected!"));
break;
case ACI_EVT_DISCONNECTED:
Serial.println(F("Disconnected or advertising timed out"));
break;
default:
break;
This function is called whenever data arrives on the RX channel
void rxCallback(uint8_t *buffer, uint8_t len)
/* Echo the same data back! */
uart.write(buffer, len);
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
Configure the Arduino and start advertising with the radio
void setup(void)
display.begin(SSD1306_SWITCHCAPVCC, 0x3D); // initialize with the I2C addr 0x3D (for the 128x64)
uart.setRXcallback(rxCallback);
uart.setACIcallback(aciCallback);
uart.setDeviceName("PROTO01"); /* 7 characters max! */
uart.begin();
Constantly checks for new events on the nRF8001
void loop()
uart.pollACI();
EDIT (more information):
I pulled the trinket off the breadboard and powered it up, no rapidly flashing pin 13 LED. It takes new uploads fine, its something to do with this sketch or these two components together. Doesn't happen with the same code for just one of the two components, only when they are combined.
