Flora hookups for midi glove
- Bombai
Hello. I want to make the midi drum glove and want to know if I can use more than 4 piezos like 6-8? If those would be hooked to the other side of flora. And how to do. Thanks!
Re: Flora hookups for midi glove
I'm afraid the Flora only has four analog input pins. There aren't any more available to read more piezo sensors.
- Bombai
Ok thanks...what else can/would go on the other side of flora? If making the plush controller I would be able to use 8 inputs right?
The Flora has a total of 8 pins that aren't either VCC or GND. The pinout diagram is here:
https://learn.adafruit.com/system/asset ... 1396787706
The four pins on the right side of the diagram can read analog inputs, the four on the left can be used for digital IO, or can communicate with other devices using I2C (SDA and SCL) or the UART/Serial protocol (TX & RX).
