I have most of the hardware sorted out now. I just need to add in the class d amp board since I couldn't get the hdmi audio working consistently.
The software question is this.... I have wired up all of the switches from the original iCade via a perma-proto to the GPIO pins on my Pi. They are all active-low, which matches up with the various tutorials on the learn system and they work well after a remapping of the pin config and recompiling retrogame. However, I also want to use one of the capacitive touch breakouts for the coin button mounted behind the coin "button" on the iCade, but it is active-high. I found this blog post, but I can't seem to get the code working.
http://elecdrome.com/icade-raspberry-pi-mod/
If you look at the end of the tutorial, the if...else code is there to swap the GPIO pin to active-high, but when I tried it, it seems to have mapped all of the pins to active-high, so of course none of the other buttons would work after the recompile.
Here is my full retrogame.c code for your enjoyment. The line numbers do not match up what was mentioned in his post, but I found what looked to be the correct line of code in the latest retrogame.c file on git that needed to be replaced with the if...else code.
Any thoughts would be appreciated. I would also be happy to share any pics or build details I have so far if anyone is interested on my build. It isn't much different than others, but there were a few tweaks I made to fit parts I already had...
You can see my additions around line 323, where line 326 is the original line that set all of the pins active low.
ADAFRUIT RETROGAME UTILITY: remaps buttons on Raspberry Pi GPIO header
to virtual USB keyboard presses. Great for classic game emulators!
Retrogame is interrupt-driven and efficient (usually under 0.3% CPU use)
and debounces inputs for glitch-free gaming.
Connect one side of button(s) to GND pin (there are several on the GPIO
header, but see later notes) and the other side to GPIO pin of interest.
Internal pullups are used; no resistors required. Avoid pins 8 and 10;
these are configured as a serial port by default on most systems (this
can be disabled but takes some doing). Pin configuration is currently
set in global table; no config file yet. See later comments.
Must be run as root, i.e. 'sudo ./retrogame &' or configure init scripts
to launch automatically at system startup.
Requires uinput kernel module. This is typically present on popular
Raspberry Pi Linux distributions but not enabled on some older varieties.
To enable, either type:
sudo modprobe uinput
Or, to make this persistent between reboots, add a line to /etc/modules:
uinput
Prior versions of this code, when being compiled for use with the Cupcade
or PiGRRL projects, required CUPCADE to be #defined. This is no longer
the case; instead a test is performed to see if a PiTFT is connected, and
one of two I/O tables is automatically selected.
Written by Phil Burgess for Adafruit Industries, distributed under BSD
License. Adafruit invests time and resources providing this open source
code, please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Copyright (c) 2013 Adafruit Industries.
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND -- FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <poll.h>
#include <signal.h>
#include <sys/mman.h>
#include <linux/input.h>
#include <linux/uinput.h>
// START HERE ------------------------------------------------------------
// This table remaps GPIO inputs to keyboard values. In this initial
// implementation there's a 1:1 relationship (can't attach multiple keys
// to a button) and the list is fixed in code; there is no configuration
// file. Buttons physically connect between GPIO pins and ground. There
// are only a few GND pins on the GPIO header, so a breakout board is
// often needed. If you require just a couple extra ground connections
// and have unused GPIO pins, set the corresponding key value to GND to
// create a spare ground point.
#define GND -1
struct {
int pin;
int key;
} *io, // In main() this pointer is set to one of the two tables below.
ioTFT[] = {
// This pin/key table is used if an Adafruit PiTFT display
// is detected (e.g. Cupcade or PiGRRL).
// Input Output (from /usr/include/linux/input.h)
{ 2, KEY_LEFT }, // Joystick (4 pins)
{ 3, KEY_RIGHT },
{ 4, KEY_DOWN },
{ 17, KEY_UP },
{ 27, KEY_Z }, // A/Fire/jump/primary
{ 22, KEY_X }, // B/Bomb/secondary
{ 23, KEY_R }, // Credit
{ 18, KEY_Q }, // Start 1P
{ -1, -1 } }, // END OF LIST, DO NOT CHANGE
// MAME must be configured with 'z' & 'x' as buttons 1 & 2 -
// this was required for the accompanying 'menu' utility to
// work (catching crtl/alt w/ncurses gets totally NASTY).
// Credit/start are likewise moved to 'r' & 'q,' reason being
// to play nicer with certain emulators not liking numbers.
// GPIO options are 'maxed out' with PiTFT + above table.
// If additional buttons are desired, will need to disable
// serial console and/or use P5 header. Or use keyboard.
ioStandard[] = {
// This pin/key table is used when the PiTFT isn't found
// (using HDMI or composite instead), as with our original
// retro gaming guide.
{ 24, KEY_LEFT }, // Joystick (4 pins)
{ 25, KEY_RIGHT },
{ 18, KEY_UP },
{ 23, KEY_DOWN },
{ 2, KEY_LEFTCTRL }, // A/Fire/jump/primary
{ 3, KEY_LEFTALT }, // B/Bomb/secondary
{ 8, KEY_5 }, // COIN, CapSensor
{ 10, KEY_ESC },
{ 9, KEY_1 }, // Player 1 Start
// For credit/start/etc., use USB keyboard or add more buttons.
{ -1, -1 } }; // END OF LIST, DO NOT CHANGE
// A "Vulcan nerve pinch" (holding down a specific button combination
// for a few seconds) issues an 'esc' keypress to MAME (which brings up
// an exit menu or quits the current game). The button combo is
// configured with a bitmask corresponding to elements in the above io[]
// array. The default value here uses elements 6 and 7 (credit and start
// in the Cupcade pinout). If you change this, make certain it's a combo
// that's not likely to occur during actual gameplay (i.e. avoid using
// joystick directions or hold-for-rapid-fire buttons).
// Also key auto-repeat times are set here. This is for navigating the
// game menu using the 'gamera' utility; MAME disregards key repeat
// events (as it should).
const unsigned long vulcanMask = (1L << 6) | (1L << 7);
const int vulcanKey = KEY_ESC, // Keycode to send
vulcanTime = 1500, // Pinch time in milliseconds
repTime1 = 500, // Key hold time to begin repeat
repTime2 = 100; // Time between key repetitions
// A few globals ---------------------------------------------------------
char
*progName, // Program name (for error reporting)
sysfs_root[] = "/sys/class/gpio", // Location of Sysfs GPIO files
running = 1; // Signal handler will set to 0 (exit)
volatile unsigned int
*gpio; // GPIO register table
const int
debounceTime = 20; // 20 ms for button debouncing
// Some utility functions ------------------------------------------------
// Set one GPIO pin attribute through the Sysfs interface.
int pinConfig(int pin, char *attr, char *value) {
char filename[50];
int fd, w, len = strlen(value);
sprintf(filename, "%s/gpio%d/%s", sysfs_root, pin, attr);
if((fd = open(filename, O_WRONLY)) < 0) return -1;
w = write(fd, value, len);
close(fd);
return (w != len); // 0 = success
// Un-export any Sysfs pins used; don't leave filesystem cruft. Also
// restores any GND pins to inputs. Write errors are ignored as pins
// may be in a partially-initialized state.
void cleanup() {
char buf[50];
int fd, i;
sprintf(buf, "%s/unexport", sysfs_root);
if((fd = open(buf, O_WRONLY)) >= 0) {
for(i=0; io[i].pin >= 0; i++) {
// Restore GND items to inputs
if(io[i].key == GND)
pinConfig(io[i].pin, "direction", "in");
// And un-export all items regardless
sprintf(buf, "%d", io[i].pin);
write(fd, buf, strlen(buf));
close(fd);
// Quick-n-dirty error reporter; print message, clean up and exit.
void err(char *msg) {
printf("%s: %s. Try 'sudo %s'.\n", progName, msg, progName);
cleanup();
exit(1);
// Interrupt handler -- set global flag to abort main loop.
void signalHandler(int n) {
running = 0;
// Returns 1 if running on early Pi board, 0 otherwise.
// Relies on info in /proc/cmdline by default; if this is
// unreliable in the future, easy change to /proc/cpuinfo.
int isRevOnePi(void) {
FILE *fp;
char buf[1024], *ptr;
int n, rev = 0;
#if 1
char *filename = "/proc/cmdline",
*token = "boardrev=",
*fmt = "%x";
#else
char *filename = "/proc/cpuinfo",
*token = "Revision", // Capital R!
*fmt = " : %x";
#endif
if((fp = fopen(filename, "r"))) {
if((n = fread(buf, 1, sizeof(buf)-1, fp)) > 0) {
buf[n] = 0;
if((ptr = strstr(buf, token))) {
sscanf(&ptr[strlen(token)], fmt, &rev);
fclose(fp);
return ((rev == 0x02) || (rev == 0x03));
// Main stuff ------------------------------------------------------------
#define BCM2708_PERI_BASE 0x20000000
#define GPIO_BASE (BCM2708_PERI_BASE + 0x200000)
#define BLOCK_SIZE (4*1024)
#define GPPUD (0x94 / 4)
#define GPPUDCLK0 (0x98 / 4)
int main(int argc, char *argv[]) {
// A few arrays here are declared with 32 elements, even though
// values aren't needed for io[] members where the 'key' value is
// GND. This simplifies the code a bit -- no need for mallocs and
// tests to create these arrays -- but may waste a handful of
// bytes for any declared GNDs.
char buf[50], // For sundry filenames
c; // Pin input value ('0'/'1')
int fd, // For mmap, sysfs, uinput
i, j, // Asst. counter
bitmask, // Pullup enable bitmask
timeout = -1, // poll() timeout
intstate[32], // Last-read state
extstate[32], // Debounced state
lastKey = -1; // Last key down (for repeat)
unsigned long bitMask, bit; // For Vulcan pinch detect
volatile unsigned char shortWait; // Delay counter
struct input_event keyEv, synEv; // uinput events
struct pollfd p[32]; // GPIO file descriptors
progName = argv[0]; // For error reporting
signal(SIGINT , signalHandler); // Trap basic signals (exit cleanly)
signal(SIGKILL, signalHandler);
// Select io[] table for Cupcade (TFT) or 'normal' project.
io = (access("/etc/modprobe.d/adafruit.conf", F_OK) ||
access("/dev/fb1", F_OK)) ? ioStandard : ioTFT;
// If this is a "Revision 1" Pi board (no mounting holes),
// remap certain pin numbers in the io[] array for compatibility.
// This way the code doesn't need modification for old boards.
if(isRevOnePi()) {
if( io[i].pin == 2) io[i].pin = 0;
else if(io[i].pin == 3) io[i].pin = 1;
else if(io[i].pin == 27) io[i].pin = 21;
// Although Sysfs provides solid GPIO interrupt handling, there's
// no interface to the internal pull-up resistors (this is by
// design, being a hardware-dependent feature). It's necessary to
// grapple with the GPIO configuration registers directly to enable
// the pull-ups. Based on GPIO example code by Dom and Gert van
// Loo on elinux.org
if((fd = open("/dev/mem", O_RDWR | O_SYNC)) < 0)
err("Can't open /dev/mem");
gpio = mmap( // Memory-mapped I/O
NULL, // Any adddress will do
BLOCK_SIZE, // Mapped block length
PROT_READ|PROT_WRITE, // Enable read+write
MAP_SHARED, // Shared with other processes
fd, // File to map
GPIO_BASE ); // Offset to GPIO registers
close(fd); // Not needed after mmap()
if(gpio == MAP_FAILED) err("Can't mmap()");
// Make combined bitmap of pullup-enabled pins:
for(bitmask=i=0; io[i].pin >= 0; i++)
if(io[i].key != GND) bitmask |= (1 << io[i].pin);
gpio[GPPUD] = 2; // Enable pullup
for(shortWait=150;--shortWait;); // Min 150 cycle wait
gpio[GPPUDCLK0] = bitmask; // Set pullup mask
for(shortWait=150;--shortWait;); // Wait again
gpio[GPPUD] = 0; // Reset pullup registers
gpio[GPPUDCLK0] = 0;
(void)munmap((void *)gpio, BLOCK_SIZE); // Done with GPIO mmap()
// All other GPIO config is handled through the sysfs interface.
sprintf(buf, "%s/export", sysfs_root);
if((fd = open(buf, O_WRONLY)) < 0) // Open Sysfs export file
err("Can't open GPIO export file");
for(i=j=0; io[i].pin >= 0; i++) { // For each pin of interest...
write(fd, buf, strlen(buf)); // Export pin
if(io[i].pin == 8) {
pinConfig(io[i].pin, "active_low", "1"); //invert for cap sensor
} else {
pinConfig(io[i].pin, "active_low", "0"); // Don't invert for rest of buttons
if(io[i].key == GND) {
// Set pin to output, value 0 (ground)
if(pinConfig(io[i].pin, "direction", "out") ||
pinConfig(io[i].pin, "value" , "0"))
err("Pin config failed (GND)");
} else {
// Set pin to input, detect rise+fall events
if(pinConfig(io[i].pin, "direction", "in") ||
pinConfig(io[i].pin, "edge" , "both"))
err("Pin config failed");
// Get initial pin value
sprintf(buf, "%s/gpio%d/value",
sysfs_root, io[i].pin);
// The p[] file descriptor array isn't necessarily
// aligned with the io[] array. GND keys in the
// latter are skipped, but p[] requires contiguous
// entries for poll(). So the pins to monitor are
// at the head of p[], and there may be unused
// elements at the end for each GND. Same applies
// to the intstate[] and extstate[] arrays.
if((p[j].fd = open(buf, O_RDONLY)) < 0)
err("Can't access pin value");
intstate[j] = 0;
if((read(p[j].fd, &c, 1) == 1) && (c == '0'))
intstate[j] = 1;
extstate[j] = intstate[j];
p[j].events = POLLPRI; // Set up poll() events
p[j].revents = 0;
j++;
} // 'j' is now count of non-GND items in io[] table
close(fd); // Done exporting
// Set up uinput
#if 1
// Retrogame normally uses /dev/uinput for generating key events.
// Cupcade requires this and it's the default. SDL2 (used by
// some newer emulators) doesn't like it, wants /dev/input/event0
// instead. Enable that code by changing to "#if 0" above.
if((fd = open("/dev/uinput", O_WRONLY | O_NONBLOCK)) < 0)
err("Can't open /dev/uinput");
if(ioctl(fd, UI_SET_EVBIT, EV_KEY) < 0)
err("Can't SET_EVBIT");
if(io[i].key != GND) {
if(ioctl(fd, UI_SET_KEYBIT, io[i].key) < 0)
err("Can't SET_KEYBIT");
if(ioctl(fd, UI_SET_KEYBIT, vulcanKey) < 0) err("Can't SET_KEYBIT");
struct uinput_user_dev uidev;
memset(&uidev, 0, sizeof(uidev));
snprintf(uidev.name, UINPUT_MAX_NAME_SIZE, "retrogame");
uidev.id.bustype = BUS_USB;
uidev.id.vendor = 0x1;
uidev.id.product = 0x1;
uidev.id.version = 1;
if(write(fd, &uidev, sizeof(uidev)) < 0)
err("write failed");
if(ioctl(fd, UI_DEV_CREATE) < 0)
err("DEV_CREATE failed");
#else // SDL2 prefers this event methodology
if((fd = open("/dev/input/event0", O_WRONLY | O_NONBLOCK)) < 0)
err("Can't open /dev/input/event0");
#endif
// Initialize input event structures
memset(&keyEv, 0, sizeof(keyEv));
keyEv.type = EV_KEY;
memset(&synEv, 0, sizeof(synEv));
synEv.type = EV_SYN;
synEv.code = SYN_REPORT;
synEv.value = 0;
// 'fd' is now open file descriptor for issuing uinput events
// Monitor GPIO file descriptors for button events. The poll()
// function watches for GPIO IRQs in this case; it is NOT
// continually polling the pins! Processor load is near zero.
while(running) { // Signal handler can set this to 0 to exit
// Wait for IRQ on pin (or timeout for button debounce)
if(poll(p, j, timeout) > 0) { // If IRQ...
for(i=0; i<j; i++) { // Scan non-GND pins...
if(p[i].revents) { // Event received?
// Read current pin state, store
// in internal state flag, but
// don't issue to uinput yet --
// must wait for debounce!
lseek(p[i].fd, 0, SEEK_SET);
read(p[i].fd, &c, 1);
if(c == '0') intstate[i] = 1;
else if(c == '1') intstate[i] = 0;
p[i].revents = 0; // Clear flag
timeout = debounceTime; // Set timeout for debounce
c = 0; // Don't issue SYN event
// Else timeout occurred
} else if(timeout == debounceTime) { // Button debounce timeout
// 'j' (number of non-GNDs) is re-counted as
// it's easier than maintaining an additional
// remapping table or a duplicate key[] list.
bitMask = 0L; // Mask of buttons currently pressed
bit = 1L;
for(c=i=j=0; io[i].pin >= 0; i++, bit<<=1) {
// Compare internal state against
// previously-issued value. Send
// keystrokes only for changed states.
if(intstate[j] != extstate[j]) {
keyEv.code = io[i].key;
keyEv.value = intstate[j];
write(fd, &keyEv,
sizeof(keyEv));
c = 1; // Follow w/SYN event
if(intstate[j]) { // Press?
// Note pressed key
// and set initial
// repeat interval.
lastKey = i;
timeout = repTime1;
} else { // Release?
// Stop repeat and
// return to normal
// IRQ monitoring
// (no timeout).
lastKey = timeout = -1;
j++;
if(intstate[i]) bitMask |= bit;
// If the "Vulcan nerve pinch" buttons are pressed,
// set long timeout -- if this time elapses without
// a button state change, esc keypress will be sent.
if((bitMask & vulcanMask) == vulcanMask)
timeout = vulcanTime;
} else if(timeout == vulcanTime) { // Vulcan timeout occurred
// Send keycode (MAME exits or displays exit menu)
keyEv.code = vulcanKey;
for(i=1; i>= 0; i--) { // Press, release
keyEv.value = i;
write(fd, &keyEv, sizeof(keyEv));
usleep(10000); // Be slow, else MAME flakes
write(fd, &synEv, sizeof(synEv));
usleep(10000);
timeout = -1; // Return to normal processing
c = 0; // No add'l SYN required
} else if(lastKey >= 0) { // Else key repeat timeout
if(timeout == repTime1) timeout = repTime2;
else if(timeout > 30) timeout -= 5; // Accelerate
keyEv.code = io[lastKey].key;
keyEv.value = 2; // Key repeat event
if(c) write(fd, &synEv, sizeof(synEv));
// Clean up
ioctl(fd, UI_DEV_DESTROY); // Destroy and
close(fd); // close uinput
cleanup(); // Un-export pins
puts("Done.");
return 0;
