Hello
and here is a problem that i have today i own two flora's and my thinking was if one work so should the new one i bought seems to be
misbehaving by when i upload a new code i hear the windows device remove sound and when i check it disconnected then have this error
in the following pictures is when i try to upload and failed but i don't see where the problem could be at and when i work and upload with the
first floar i have it works fine any solutions?
Flora Time out
- Tron32
Flora Time out
- Attachments
- Upload Error in whole
- 1.png (141.06 KiB) Viewed 509 times
- the board is right
- 2.png (159.89 KiB) Viewed 509 times
- and the boot loader
- 3.png (148.22 KiB) Viewed 509 times
Re: Flora Time out
The Flora doesn't use the Programmer menu.
There should be an item under the Serial Port menu for the Flora. Have you installed the drivers as shown in the tutorial?
https://learn.adafruit.com/getting-star ... d-software
- Tron32
Re: Flora Time out
i have and it works for only one works fine but the other is having the error.
Re: Flora Time out
Check your COM settings with the Flora that doesn't work connected. What do you get for hardware recognition?
- Tron32
Re: Flora Time out
what i'm i looking for in the com settings it can see it but it would fail to upload around the 90% mark and would disconnected. but why do i have to install another driver
when is set one up before? should it work with the first install?
- Attachments
- device manager can see the flora that has the problem
- 5.png (135.82 KiB) Viewed 442 times
Re: Flora Time out
The same driver should work for both Floras.
Sometimes a Flora's bootloader gets corrupted and the computer can't recognize it at a hardware level. When that happens, the machine doesn't report the device as "Adafruit Flora" in the COM settings.
There may be some kind of trouble with the COM port. Let me check with the folks who have more experience with the Flora on Windows.
- Tron32
Re: Flora Time out
Thanks mike i hope it would be an easy fix.
And agian thanks for the help I stand by for further instructions
- adafruit2
Re: Flora Time out
ok please turn on 'verbose output on upload' in the preferences window
then try uploading blink or something and post the output in a 'code block' so its nice to read :)
- Tron32
Re: Flora Time out
Ok heres the verbose output on upload like you ask adafruit2
- Attachments
- Start of verbose output on upload
- 6.png (117.57 KiB) Viewed 419 times
- 8.png (116.93 KiB) Viewed 419 times
- End verbose output on upload
- 9.png (125.23 KiB) Viewed 419 times
- adafruit2
Re: Flora Time out
hi, i mean *copy and paste* the output text into the response, not a screen shot... easier that way :)
what does the flora do when you press the reset button? does the red led pulse?
- Tron32
Re: Flora Time out
I am relay Sorry About adafruit2 i just thought pictures spoke more than words :)
and back to the Flora problem at hand no it would just have the green on led and the ember RX led flash once or twice for a second and do nothing else
weird. :\
weird. :\
- adafruit_support_rick
Re: Flora Time out
The output shows that it's looking for the Flora on COM 14, but your Flora is showing up as COM 15 in Device Manager. Check your COM port selection.
- Tron32
Re: Flora Time out
well it would work for the COM 14 and 15 with the original Flora so it not the problem and it still is the same with an original problem rick.
so what else could it be
Binary sketch size: 4,892 bytes (of a 28,672 byte maximum)
Forcing reset using 1200bps open/close on port COM15
PORTS {COM15, } / {COM15, } => {}
PORTS {COM15, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
processing.app.debug.RunnerException: Couldn’t find a Leonardo on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:153)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:619)
- adafruit2
Re: Flora Time out
Lets get you a new flora! email support@adafruit and ask for a new one :)
- Tron32
Re: Flora Time out
ok should use gmail account for my Requests for a new flora
