I want to read the low battery pin on the PowerBoost 1000 and read it with a Propeller MCU. The problem is that the voltage on that pin is pulled high to BAT which can be as high as 4.2v, much too high for the Propeller. So I put a 100K Ohm resistor in series so the voltage would be lower. The problem is that with a charged battery the pin is reading all over the place. It's not staying a steady 1, but randomly jumps between 1 and 0. Is my resistor the wrong size so it's lowering the voltage too much? Should the pin be pulled high as well? Thanks,
Jason
PowerBoost 1000 low battery pin problems
Re: PowerBoost 1000 low battery pin problems
A 100k resistor won't lower the voltage by itself. You'd need another one between the pin and GND to make a voltage divider.
