Adafruit Motor HAT for pi test examples
- adafruit_support_rick
Re: Adafruit Motor HAT for pi test examples
What do you get from the command sudo i2cdetect -y 1
- JTibbetts
Exactly the same as the other guy
So, I2Cdetect is finding the HAT at 0x60?
What error messages are you getting?
What do you mean, "it won't power the motor"? Do you have an external power supply attached to the HAT?
Can you post some pictures of both sides of the HAT?
- Darkvadera4b6
I had exactly the same problem when running the dctest.py ir says error check i2c address ..so r u saying that if I change the address to 0x60 instead of 0x61 it'll work ..I'll give this a try when I get home
- JTibbetts
Hi, Thanks for trying to help, Found out today that my partner melted the board meaning we will have to replace it, Sorry for wasting your time.
- adafruit2
updated the code - it should have been 0x60, was a typo!
the current github code is fixed (or, if you have the older code, just change the 0x61 to 0x60)
sorry about that!
sorry about that!
- qd11
Hi there,
I recently purchased Motor Hat and I am experiencing difficulties to get it running.
I followed to the letter the guide here https://learn.adafruit.com/adafruits-ra ... guring-i2c
but when I do sudo i2cdetect -y 1
I get all blanks, i.e.,
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Although: ls /dev/*i2c*
/dev/i2c-1
Respective modules are loaded too.
lsmod
Module Size Used by
i2c_dev 5859 0
i2c_bcm2708 4770 0
I've got Raspberry Pi 3 model B with Linux RPi3 4.4.13-v7+ #894 SMP Mon Jun 13 13:13:27 BST 2016 armv7l GNU/Linux
Motor Hat is powered, the green "power" diode is lit up.
What seems to be a problem? Thanks.
On the side note, I also have a SenseHat, this guy works ok.
/dev/i2c-1
lsmod
Module Size Used by
i2c_dev 5859 0
i2c_bcm2708 4770 0
post some clear, detailed pictures of both sides of the Hat
- qd11
Here you go
Do you suspect hw problems?
I could also try to get a fresh raspbian.
You haven't soldered anything to the hat. You have to solder on the headers.
- qd11
OK, I am new to these things, I apologize for my ignorance.
I followed the guide over here https://learn.adafruit.com/simple-raspb ... t/assembly
It says nothing about soldering and SenseHat works without soldering, so I assumed...
All right, thanks for your help, I will solder things as here
https://learn.adafruit.com/adafruit-dc- ... i/assembly
Yeah - the hat is already assembled in the robot tutorial. I'll add a reference to the assembly instructions.
- qd11
OK, soldered it works as charm. thanks.
