try to run the test examples for the HAT I recently bought, but they do not run.
I am getting IOError: Errno 2 no such file or directory
I did everything in the setup procedure correctly.
Please help me.
Adafruit Motor HAT for pi test examples
- adafruit_support_rick
Re: Adafruit Motor HAT for pi test examples
Please post the entire error message. It may be several lines long. Which python example are you running ?
- gurmar
the screen is:
pi@raspberrypi ~/Adafruit-Motor-HAT-Python-Library/examples $ sudo python StepperTest.py
File "StepperTest.py", line 3, in <module>
from Adafruit_MotorHAT import Adafruit_MotorHAT, Adafruit_DCMotor, Adafruit_StepperMotor
File "build/bdist.linux-armv6l/egg/Adafruit_MotorHAT/__init__.py", line 1, in <module>
File "build/bdist.linux-armv6l/egg/Adafruit_MotorHAT/Adafruit_MotorHAT.py", line 3, in <module>
File "build/bdist.linux-armv6l/egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py", line 11, in <module>
File "build/bdist.linux-armv6l/egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py", line 35, in PWM
File "build/bdist.linux-armv6l/egg/Adafruit_MotorHAT/Adafruit_I2C.py", line 43, in __init__
IOError: [Errno 2] No such file or directory
It looks like you haven't configured I2C on your Pi.
https://learn.adafruit.com/adafruits-ra ... guring-i2c
- gurmar
thanks a lot. finally I managed it work with your help.
- jhroelofs
I'm having a similar problem- set up everything, I felt like I instalelled I2C and python properly, but I keep getting this error message:
pi@raspberrypi ~/Adafruit-Motor-HAT-Python-Library/examples $ sudo python DCTest.py
File "DCTest.py", line 2, in <module>
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.2.0-py2.7.egg/Adafruit_MotorHAT/__init__.py", line 1, in <module>
from .Adafruit_MotorHAT import Adafruit_StepperMotor, Adafruit_DCMotor, Adafruit_MotorHAT
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.2.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_MotorHAT.py", line 3, in <module>
from Adafruit_PWM_Servo_Driver import PWM
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.2.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py", line 11, in <module>
class PWM :
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.2.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py", line 35, in PWM
general_call_i2c = Adafruit_I2C(0x00)
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.2.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_I2C.py", line 43, in __init__
self.bus = smbus.SMBus(busnum if busnum >= 0 else Adafruit_I2C.getPiI2CBusNumber())
Any ideas?
class PWM :
Any ideas?
What do you get from the command i2cdetect -y 1
- jhroelofs
I had to run it as root, and got the following:
pi@raspberrypi ~ $ i2cdetect -y 1
Error: Could not open file `/dev/i2c-1': Permission denied
Run as root?
pi@raspberrypi ~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: 60 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
Run as root?
- jhroelofs
Also, when I try to run the example DCTest.py, I get
Error accessing 0x61: Check your I2C address
Repeating over and over until I shut the pi down
- jhroelofs
I changed the "addr=0x61" in the DCTest.py script to a 60 and it worked! Not sure exactly what happened but we're good to go!
- bdog253
Hey guys,
I was having the same issues with the addressing and fixed it by changing it to use 0x60. The issue I'm running into now is that when I run the script the first time it starts the motor but then reboots the pi. Once rebooted if I run the script again it seems to work okay. When I hit ctrl-C to get out of the loop and then try and run again it then reboots.
Did I screw up my hat while soldering? Is there a quick way to test if the hat is still okay?
Thanks in advance.
*** EDIT ***
Upon further investigation it would seem when running the code the first time it just starts the motor at half speed and then reboots. When I commented out the line of code that says myMotors.setSpeed(150) everything seemed to work okay and it no longer reboots.
Thanks in advance.
*** EDIT ***
So you're good to go?
- bdog253
Yes thanks. Everything seems to be working as long as I don't have that line of code. Not sure why. I've written a bunch of other scripts to test out 3 motors and everything seems okay. Thanks again!
- JTibbetts
Hi, we are also getting similar issues (by this i mean it won't power the motor and get error messages out the yingyang) but, changing it to 60 did nothing.
Please help.
Please help.
