I'm trying to control some 12V fans with an arduino and am using a N-channel MOSFET to power them. I have it wired up in a fairly typical fashion: Drain is grounded, source to the motor and +12V, gain to the PWM pin.
Variation on the gain has very little effect on the output to the motor. My main problem is I cannot get the MOSFET to turn off! Even if the gain is straight up grounded, the motors are still at (estimating) 90% current draw. I swapped another MOSFET in to check, but with the same result, so I must be doing something wrong. I don't have a lot of experience with MOSFETS, so not sure what I'm doing wrong but it's driving me crazy!!!! Please help! Thanks,
Tyler
Can't get MOSFET to turn off
Re: Can't get MOSFET to turn off
If you're using and N-mosfet you need to swap the source and drain.
Source points toward GND, drain points toward VCC.
Oh boy. Sorry for such a dumb question and thank you greatly for setting me straight. I guess the current was going right through the internal diode. I swore I tried swapping the source and drain to no avail, but... in any event, you were right. It works great now. Thanks!
Tyler
Tyler
No worries.. the simple things are the easiest ones to get backwards.
I once melted a nice hole in a breadboard by putting a 6v Zener diode in so it was forward biased. ;-)
