Im trying to calibrate my neo geo watch i got all the data from the pololu lsm303calibrate.ino
min: { -467, -541, -597} max: { +405, +301, +233}
when i look at the Neogeo sketch i see no spot to plug the values in.
can someone help ??
Here is the current Neo Geo Code i am using
// Test code for Adafruit Flora GPS modules
// This code shows how to listen to the GPS module in an interrupt
// which allows the program to have more 'freedom' - just parse
// when a new NMEA sentence is available! Then access data when
// desired.
// Tested and works great with the Adafruit Flora GPS module
// ------> http://adafruit.com/products/1059
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <Time.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM303_U.h>
Adafruit_GPS GPS(&Serial1);
/* Assign a unique ID to this sensor at the same time */
Adafruit_LSM303_Mag_Unified mag = Adafruit_LSM303_Mag_Unified(12345);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
#define GPSECHO false
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
// WAYPOINT |
//Please enter the latitude and longitude of your |
//desired destination: |
#define GEO_LAT 48.009551
#define GEO_LON -88.771131
//Your NeoPixel ring may not line up with ours. |
//Enter which NeoPixel led is your top LED (0-15). |
#define TOP_LED 1
//Your compass module may not line up with ours. |
//Once you run compass mode, compare to a separate |
//compass (like one found on your smartphone). |
//Point your TOP_LED north, then count clockwise |
//how many LEDs away from TOP_LED the lit LED is |
#define LED_OFFSET 0
// Navigation location
float targetLat = GEO_LAT;
float targetLon = GEO_LON;
// Trip distance
float tripDistance;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(16, 6, NEO_GRB + NEO_KHZ800);
// Offset hours from gps time (UTC)
//const int offset = 1; // Central European Time
//const int offset = -4; // Eastern Daylight Time (USA)
//const int offset = -5; // Central Daylight Time (USA)
const int offset = -8; // Pacific Standard Time (USA)
//const int offset = -7; // Pacific Daylight Time (USA)
int topLED = TOP_LED;
int BANNED = LED_OFFSET;
int lastMin = 16;
int lastHour = 16;
int startLED = 0;
int startLEDlast = 16;
int lastCombined = 0;
int start = 0;
int mode = 0;
int lastDir = 16;
int dirLED_r = 0;
int dirLED_g = 0;
int dirLED_b = 255;
int compassReading;
// Calibration offsets
float magxOffset = 2.55;
float magyOffset = 27.95;
// Pushbutton setup
int buttonPin = 10; // the number of the pushbutton pin
int buttonState; // the current reading from the input pin
int lastButtonState = HIGH; // the previous reading from the input pin
long buttonHoldTime = 0; // the last time the output pin was toggled
long buttonHoldDelay = 2500; // how long to hold the button down
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
long menuDelay = 2500;
long menuTime;
float fLat = 0.0;
float fLon = 0.0;
void setup()
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.begin(115200);
Serial.println("Adafruit GPS library basic test!");
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
/* Initialise the sensor */
if(!mag.begin())
/* There was a problem detecting the LSM303 ... check your connections */
Serial.println("Ooops, no LSM303 detected ... Check your wiring!");
while(1);
// Ask for firmware version
Serial1.println(PMTK_Q_RELEASE);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// Make input & enable pull-up resistors on switch pins for pushbutton
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH);
uint32_t gpsTimer = millis();
uint32_t startupTimer = millis();
uint32_t compassTimer = millis();
void loop() // run over and over again
compassCheck();
// read the state of the switch into a local variable:
int buttonState = digitalRead(buttonPin);
if (buttonState == LOW) {
buttonCheck();
lastButtonState = buttonState;
//Serial.println(buttonState);
// read data from the GPS in the 'main loop'
char c = GPS.read();
// if you want to debug, this is a good time to do it!
if (GPSECHO)
if (c) Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// if millis() or timer wraps around, we'll just reset it
if (gpsTimer > millis()) gpsTimer = millis();
if (start == 0) {
if (GPS.fix) {
// set the Time to the latest GPS reading
setTime(GPS.hour, GPS.minute, GPS.seconds, GPS.day, GPS.month, GPS.year);
delay(50);
adjustTime(offset * SECS_PER_HOUR);
delay(500);
tripDistance = (double)calc_dist(fLat, fLon, targetLat, targetLon);
start = 1;
// approximately every 60 seconds or so, update time
if ((millis() - gpsTimer > 60000) && (start == 1)) {
gpsTimer = millis(); // reset the timer
if (GPS.fix) {
delay(50);
delay(500);
if (GPS.fix) {
fLat = decimalDegrees(GPS.latitude, GPS.lat);
fLon = decimalDegrees(GPS.longitude, GPS.lon);
if (mode == 0) {
clockMode();
if (mode == 1) {
navMode();
if (mode == 2) {
compassMode();
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void buttonCheck() {
menuTime = millis();
if (buttonState == LOW && lastButtonState == HIGH) {
buttonHoldTime = millis();
if (buttonState == LOW && lastButtonState == LOW) {
if ((millis() - buttonHoldTime) > buttonHoldDelay) {
if(mode == 2) {
mode = 0;
lastMin = 16;
lastHour = 16;
colorWipe(strip.Color(0, 0, 0), 20);
else {
mode = mode + 1;
void clockMode() {
if (start == 1) {
strip.setPixelColor(startLEDlast, strip.Color(0, 0, 0));
strip.show();
float gpsMin = (minute() + (second()/60.0));
unsigned int ledMin = 0;
int minTemp = 0;
minTemp = topLED - (gpsMin + 1.875)/3.75;
if (minTemp < 0) {
ledMin = minTemp + 16;
else {
ledMin = minTemp;
float gpsHour = (hour() + (minute()/60.0));
if (gpsHour > 12) {
gpsHour = gpsHour - 12;
unsigned int ledHour = 0;
int hourTemp = 0;
hourTemp = topLED - (gpsHour + .375)/.75;
if (hourTemp < 0) {
ledHour = hourTemp + 16;
else {
ledHour = hourTemp;
if ((ledHour == ledMin) && (lastCombined == 0)) {
strip.setPixelColor(lastHour, strip.Color(0, 0, 0));
strip.setPixelColor(lastMin, strip.Color(0, 0, 0));
strip.setPixelColor(ledHour, strip.Color(255, 0, 255));
strip.show();
lastCombined = 1;
lastHour = ledHour;
lastMin = ledMin;
else {
if (lastHour != ledHour) {
strip.setPixelColor(ledHour, strip.Color(255, 50, 0));
strip.show();
lastHour = ledHour;
if (lastMin != ledMin) {
strip.setPixelColor(ledMin, strip.Color(200, 200, 0));
if (lastCombined == 1) {
strip.setPixelColor(ledHour, strip.Color(255, 0, 0));
lastCombined = 0;
strip.show();
lastMin = ledMin;
else {
if (startupTimer > millis()) startupTimer = millis();
// approximately every 10 seconds or so, update time
if (millis() - startupTimer > 200) {
startupTimer = millis(); // reset the timer
if (startLED == 16) {
startLED = 0;
strip.setPixelColor(startLED, strip.Color(0, 255, 0));
strip.show();
startLEDlast = startLED;
startLED++;
//delay(200);
void navMode() {
if (start == 1) {
compassCheck();
headingDistance((double)calc_dist(fLat, fLon, targetLat, targetLon));
if ((calc_bearing(fLat, fLon, targetLat, targetLon) - compassReading) > 0) {
compassDirection(calc_bearing(fLat, fLon, targetLat, targetLon)-compassReading);
else {
compassDirection(calc_bearing(fLat, fLon, targetLat, targetLon)-compassReading+360);
else {
startLED = 0;
strip.setPixelColor(startLED, strip.Color(0, 0, 255));
strip.show();
startLED++;
int calc_bearing(float flat1, float flon1, float flat2, float flon2)
float calc;
float bear_calc;
float x = 69.1 * (flat2 - flat1);
float y = 69.1 * (flon2 - flon1) * cos(flat1/57.3);
calc=atan2(y,x);
bear_calc= degrees(calc);
if(bear_calc<=1){
bear_calc=360+bear_calc;
return bear_calc;
void headingDistance(int fDist)
//Use this part of the code to determine how far you are away from the destination.
//The total trip distance (from where you started) is divided into five trip segments.
float tripSegment = tripDistance/5;
if (fDist >= (tripSegment*4)) {
dirLED_r = 255;
dirLED_g = 0;
dirLED_b = 0;
if ((fDist >= (tripSegment*3))&&(fDist < (tripSegment*4))) {
dirLED_r = 255;
dirLED_g = 0;
dirLED_b = 0;
if ((fDist >= (tripSegment*2))&&(fDist < (tripSegment*3))) {
dirLED_r = 255;
dirLED_g = 255;
dirLED_b = 0;
if ((fDist >= tripSegment)&&(fDist < (tripSegment*2))) {
dirLED_r = 255;
dirLED_g = 255;
dirLED_b = 0;
if ((fDist >= 5)&&(fDist < tripSegment)) {
dirLED_r = 255;
dirLED_g = 255;
dirLED_b = 0;
if ((fDist < 5)) { // You are now within 5 meters of your destination.
//Serial.println("Arrived at destination!");
dirLED_r = 0;
dirLED_g = 255;
dirLED_b = 0;
unsigned long calc_dist(float flat1, float flon1, float flat2, float flon2)
float dist_calc=0;
float dist_calc2=0;
float diflat=0;
float diflon=0;
diflat=radians(flat2-flat1);
flat1=radians(flat1);
flat2=radians(flat2);
diflon=radians((flon2)-(flon1));
dist_calc = (sin(diflat/2.0)*sin(diflat/2.0));
dist_calc2= cos(flat1);
dist_calc2*=cos(flat2);
dist_calc2*=sin(diflon/2.0);
dist_calc +=dist_calc2;
dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
dist_calc*=6371000.0; //Converting to meters
return dist_calc;
// Convert NMEA coordinate to decimal degrees
float decimalDegrees(float nmeaCoord, char dir) {
uint16_t wholeDegrees = 0.01*nmeaCoord;
int modifier = 1;
if (dir == 'W' || dir == 'S') {
modifier = -1;
return (wholeDegrees + (nmeaCoord - 100.0*wholeDegrees)/60.0) * modifier;
void compassMode() {
dirLED_r = 0;
dirLED_g = 0;
dirLED_b = 255;
compassDirection(compassReading);
void compassCheck() {
if (compassTimer > millis()) compassTimer = millis();
if (millis() - compassTimer > 50) {
/* Get a new sensor event */
sensors_event_t event;
mag.getEvent(&event);
float Pi = 3.14159;
compassTimer = millis(); // reset the timer
// Calculate the angle of the vector y,x
float heading = (atan2(event.magnetic.y + magyOffset,event.magnetic.x + magxOffset) * 180) / Pi;
// Normalize to 0-360
if (heading < 0)
heading = 360 + heading;
compassReading = heading;
void compassDirection(int compassHeading)
//Serial.print("Compass Direction: ");
//Serial.println(compassHeading);
unsigned int ledDir = 2;
int tempDir = 0;
//Use this part of the code to determine which way you need to go.
//Remember: this is not the direction you are heading, it is the direction to the destination (north = forward).
if ((compassHeading > 348.75)||(compassHeading < 11.25)) {
tempDir = topLED;
for(int i = 1; i < 16; i++){
float pieSliceCenter = 45/2*i;
float pieSliceMin = pieSliceCenter - 11.25;
float pieSliceMax = pieSliceCenter + 11.25;
if ((compassHeading >= pieSliceMin)&&(compassHeading < pieSliceMax)) {
if (mode == 2 ) {
tempDir = topLED - i;
else {
tempDir = topLED + i;
if (tempDir > 15) {
ledDir = tempDir - 16;
else if (tempDir < 0) {
ledDir = tempDir + 16;
else {
ledDir = tempDir;
if (mode == 1) {
ledDir = ledDir + BANNED;
if (ledDir > 15) {
ledDir = ledDir - 16;
else {
if (ledDir > 15) {
if (lastDir != ledDir) {
strip.setPixelColor(lastDir, strip.Color(0, 0, 0));
strip.setPixelColor(ledDir, strip.Color(dirLED_r, dirLED_g, dirLED_b));
strip.show();
lastDir = ledDir;
