using a rpi B+,pitft and the latest cupcade image,i can boot and contol it using the GPIO but no matter what i try usb input just won't work so i can't edit the screen settings.
is there a simple solution or is it the piB+ itself?
keyboard not working in Gamera/Cupcade
Re: keyboard not working in Gamera/Cupcade
Try another SD card with a copy of Raspbian and see if the keyboard works with that.
- pburgess
From the guide:
You could try installing advmame, etc. from the Cupcade image over a B+ compatible Raspbian, but no guarantees, and advmame is -extremely- fussy about certain file locations and things.
There was a peripheral controller change on the B+ which is not compatible with the version of Raspbian used in the Cupcade image. We've not produced a new image yet because it's actually a pretty big undertaking, and the hardware and OS are moving targets (now with the Pi 2 out, which is totally WAY incompatible). It might be revisited once things have settled a bit, but there's no ETA.Cupcade requires a Raspberry Pi Model B with mounting holes. The new B+ board, and early Model Bs with no mounting holes, will NOT work.
