Hi everybody,
I hope someone can help my with my project.
I wired my Triple Axis Accelerometer (https://www.adafruit.com/products/1231) to my Pro Trinket. I'd like to use the input that comes from the Accelerometer, being processed by the Pro Trinket to finally trigger sounds.
Example: Accelerometer detects tilt, Pro trinket processes and triggers Soundboard to play a sound.
I read the specs and watched the video to this
Soundboard with Amp
https://www.adafruit.com/products/2217
It's often emphasized, that you don't need a microcontroller with this. But can I use the output from my Pro Trinket to trigger sounds instead of buttons?
If not, is there another breakout I could use instead?
Best Regards
Dom
Audio FX Soundboard triggered by input from Pro Trinket
- MrCurbsurfer
- adafruit_support_rick
Re: Audio FX Soundboard triggered by input from Pro Trinket
Sure. All you need to do is pull the pin low to make the sound play. Connect it to a digital output on your pro trinket. Write the output high normally, and low to trigger the sound. Make sure you have a ground connection between the trinket and the audio fx boardMrCurbsurfer wrote:can I use the output from my Pro Trinket to trigger sounds instead of buttons?
- MrCurbsurfer
Thanks for the fast reply! Then I'll get that breakout
I really have to say: You guys are awsome! Great hardware, great support. Thanks to you I got finally started with prototyping, soldering and all that stuff =)
Best Regards
Dom
Best Regards
Dom
