I installed Neopixels in my buddy's car that react to sound based on the "Sound-Reactive LED Color Organ" project
https://learn.adafruit.com/trinket-soun ... olor-organ
His car engine is to loud and interferes with the sound reaction.
Can I splice into the speakers wire and bypass the mic to avoid the engine noise? How? What do i need in place of the mic? Will this option slow the sound reaction time?
LED Organ without mic
- adafruit_support_rick
Re: LED Organ without mic
Don't connect the speaker wires to the analog input. You'll blow out the microprocessor. You need a line-level signal. Is there a line-out on the sound system?
- Jevries
So basically hook up the wires to the phone jack output on the audio device instead of having it run to the small mic, right?
yes, that is correct.
- Jevries
Thank you for your reply!
I'm working on a miniature 3.6V 1/25 scale Sonic Color bar that were very popular in the '70's attached under the dash cruising the boulevard.
This version I soldered my own circuit board but I recently bought the trinket to see if it can be improved. I use the smallest leds avialable.
- Sequence 01.Still001.jpg (519.09 KiB) Viewed 164 times
cool idea!
