No animation, power light on. I'm pretty sure the wiring is correct. And code. I get this message below:
Binary sketch size: 1,872 bytes (of a 5,310 byte maximum)
avrdude: usbdev_open(): did not find any USB device "usb"
Also my windows does recognize it as Trinket.
Not sure about the orientation on the LED matrix, I search everywhere but see no indications which way it goes. I know LED's are polarity sensitive. Does it matter?
Thanks,
Eric
- eschneider777
- adafruit_support_mike
Re: avrdude: usbdev_open(): did not find any USB device "usb
Post a photo of your hardware and connections, and the code you're using (between CODE tags please) and we'll take a look.
- eschneider777
I'm using the example code, unchanged.
- Attachments
- 2.jpg (794.63 KiB) Viewed 1212 times
- 1.jpg (783.03 KiB) Viewed 1212 times
Your connections look good.
Do you have 'USBtinyISP' selected under the Tools->Programmer menu, and are you pressing the Trinket's Reset button about the same time as you click the button to compile and upload code in the Arduino IDE?
- eschneider777
That was it!
Was that in the directions?, don't remember seeing that...
Thanks,
Eric
Thanks,
Eric
- eschneider777
yep, I see it.
I skimmed through pretty quick, man there's a lot of directions for this stuff.
