I'm working with both a RaspberryPI and OSX, and I'm trying to get a project set up, which is similar to Phillip Burgess's NeoPixel Curtain Project (https://learn.adafruit.com/1500-neopixe ... y/overview) I am working with 3 Fadecandy boards and am trying to pass the fadecady server a different configuration file to use so that I can properly map the LEDs I have in my project. However, I noticed (both with RPI and OSX) that whenever I try to run the server from the command line, as it says to in the help, fcserver [<config.json>], I get the following return:
"Error opening config file: No such file or directory"
This happens whether I am running from the relative directory I have both the sever and the JSON file in, or giving the command with absolute paths. I am new at this, so perhaps I am doing something wrong.
Can anyone tell me how I can get the server to use a different configuration file other than the default one? I can't seem to get this to work, and I'm hoping it's me and not a bug.
Fadecandy Sever Configuration File
Re: Fadecandy Sever Configuration File
You'll probably need to check with the Fadecandy forum on that: https://groups.google.com/forum/#!forum/fadecandy
- mattjet27
Thanks! I'll try reposting there.
