7-Segment LED HT16K33 Backpack
- sourav1230
Hi. I was working on this project for a while now, where i use a keypad to enter in a time, and turn the LED display into a timer. The problem im having is that when i hook the LED display up and load an example from the LED_Backpack library, nothing happens. It just stays blank. I don't know if its a defect, if im doing something wrong, but i'm pretty sure i got the wiring right, and i soldered everything. Someone PLS help. Thx.
Re: 7-Segment LED HT16K33 Backpack
The photos above are a bit too small. We need to see things like details of the solder joints and the connections between the backpack and the Arduino.
800x600 images ususally work.
- sourav1230
This is a library for our I2C LED Backpacks
Designed specifically to work with the Adafruit LED 7-Segment backpacks
----> http://www.adafruit.com/products/881
----> http://www.adafruit.com/products/880
----> http://www.adafruit.com/products/879
----> http://www.adafruit.com/products/878
These displays use I2C to communicate, 2 pins are required to
interface. There are multiple selectable I2C addresses. For backpacks
with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
with 3 Address Select pins: 0x70 thru 0x77
products from Adafruit!
// Enable one of these two #includes and comment out the other.
// Conditional #include doesn't work due to Arduino IDE shenanigans.
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
//#include <TinyWireM.h> // Enable this line if using Adafruit Trinket, Gemma, etc.
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_7segment matrix = Adafruit_7segment();
#ifndef __AVR_ATtiny85__
Serial.begin(9600);
Serial.println("7 Segment Backpack Test");
#endif
matrix.begin(0x70);
// print a hex number
matrix.print(0xBEEF, HEX);
matrix.writeDisplay();
delay(500);
// print a floating point
matrix.print(12.34);
delay(500);
// print with print/println
for (uint16_t counter = 0; counter < 9999; counter++) {
matrix.println(counter);
delay(10);
// method #2 - draw each digit
uint16_t blinkcounter = 0;
boolean drawDots = false;
for (uint16_t counter = 0; counter < 9999; counter ++) {
matrix.writeDigitNum(0, (counter / 1000), drawDots);
matrix.writeDigitNum(1, (counter / 100) % 10, drawDots);
matrix.drawColon(drawDots);
matrix.writeDigitNum(3, (counter / 10) % 10, drawDots);
matrix.writeDigitNum(4, counter % 10, drawDots);
blinkcounter+=50;
if (blinkcounter < 500) {
drawDots = false;
} else if (blinkcounter < 1000) {
drawDots = true;
} else {
blinkcounter = 0;
delay(10);
Your connections look good, so you may have a dead backpack.
Send a note to [email protected] with a link to this thread and the folks there will get you a replacement.
