http://www.adafruit.com/products/200?&m ... cts_id=200
Will the indoor lighting also charge this solar panel? It specifically says, "typical outdoor use", and was wondering if it can be used for indoor use with lightings.
If not, is there such at adafruit?
Solar Panel for Indoor
Re: Solar Panel for Indoor
It will produce some output in indoor light. But not nearly as much as it will get from direct sunlight. Full direct sunlight has about 1,000 times as much energy as typical indoor lighting. So, for that 2W panel, you can estimate about 2 millwatts.
