Programed the board and tested prior to pouring the plastic. All worked just fine. The Sketch was like 2.5k.
I finally got the statue complied and powered it up and put it in a darker corner of the display case and noticed the timing was just a bit off. I opened the sketch on a new pc loaded the Adafruit version of Arduino 1.6.3 added in the fastled library and the neopixel library. Now the sketch says it will no longer fit on the Gemma. Thinking I did something wrong I found the code again from the projects and did the compile and now getting other errors. Can someone help me out with this? Or point me the direction I can update the code on the Gemma with this code?
Thank You.
Neopixel Cosmic Turtle
Sketches
Here is my original code.
#include "FastLED.h"
#define LED_PIN 2
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
#define NUM_LEDS 7
CRGB leds[NUM_LEDS];
CRGBPalette16 currentPalette;
TBlendType currentBlending;
// Twinkling 'holiday' lights that fade up and down in brightness.
// Colors are chosen from a palette; a few palettes are provided.
// The basic operation is that all pixels stay black until they
// are 'seeded' with a relatively dim color. The dim colors
// are repeatedly brightened until they reach full brightness, then
// are darkened repeatedly until they are fully black again.
// A set of 'directionFlags' is used to track whether a given
// pixel is presently brightening up or darkening down.
// For illustration purposes, two implementations of directionFlags
// are provided: a simple one-byte-per-pixel flag, and a more
// complicated, more compact one-BIT-per-pixel flag.
// Darkening colors accurately is relatively easy: scale down the
// existing color channel values. Brightening colors is a bit more
// error prone, as there's some loss of precision. If your colors
// aren't coming our 'right' at full brightness, try increasing the
// STARTING_BRIGHTNESS value.
// -Mark Kriegsman, December 2014
#define MASTER_BRIGHTNESS 255 // change this to change overall brightness
#define STARTING_BRIGHTNESS 255 // change this to change maximum brightness
#define FADE_IN_SPEED 10 // lower number fades in slower
#define FADE_OUT_SPEED 100 // higher number hangs around longer
#define DENSITY 255
delay(2000);
FastLED.addLeds<LED_TYPE,LED_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(MASTER_BRIGHTNESS);
currentBlending = BLEND;
CRGBPalette16 gPalette;
void loop()
//Un-comment the line with the colors you like best
gPalette = OceanColors_p;
//gPalette = RainbowColors-p;
//gPalette = HeatColors-p;
//gPalette = PartyColors-p;
//gPalette = CloudColors-p;
//gPalette = RainbowStripeColors-p;
colortwinkles();
FastLED.show();
FastLED.delay(1000); // change this to change overall speed
enum { GETTING_DARKER = 0, GETTING_BRIGHTER = 1 };
void colortwinkles()
// Make each pixel brighter or darker, depending on
// its 'direction' flag.
brightenOrDarkenEachPixel( FADE_IN_SPEED, FADE_OUT_SPEED);
// Now consider adding a new random twinkle
if( random8() < DENSITY ) {
int pos = random16(NUM_LEDS);
if( !leds[pos]) {
leds[pos] = ColorFromPalette( gPalette, random8(), STARTING_BRIGHTNESS, NOBLEND);
setPixelDirection(pos, GETTING_BRIGHTER);
void brightenOrDarkenEachPixel( fract8 fadeUpAmount, fract8 fadeDownAmount)
for( uint16_t i = 0; i < NUM_LEDS; i++) {
if( getPixelDirection(i) == GETTING_DARKER) {
// This pixel is getting darker
leds[i] = makeDarker( leds[i], fadeDownAmount);
} else {
// This pixel is getting brighter
leds[i] = makeBrighter( leds[i], fadeUpAmount);
// now check to see if we've maxxed out the brightness
if( leds[i].r == 255 || leds[i].g == 255 || leds[i].b == 255) {
// if so, turn around and start getting darker
setPixelDirection(i, GETTING_DARKER);
CRGB makeBrighter( const CRGB& color, fract8 howMuchBrighter)
CRGB incrementalColor = color;
incrementalColor.nscale8( howMuchBrighter);
return color + incrementalColor;
CRGB makeDarker( const CRGB& color, fract8 howMuchDarker)
CRGB newcolor = color;
newcolor.nscale8( 255 - howMuchDarker);
return newcolor;
// For illustration purposes, there are two separate implementations
// provided here for the array of 'directionFlags':
// - a simple one, which uses one byte (8 bits) of RAM for each pixel, and
// - a compact one, which uses just one BIT of RAM for each pixel.
// Set this to 1 or 8 to select which implementation
// of directionFlags is used. 1=more compact, 8=simpler.
#define BITS_PER_DIRECTION_FLAG 1
#if BITS_PER_DIRECTION_FLAG == 8
// Simple implementation of the directionFlags array,
// which takes up one byte (eight bits) per pixel.
uint8_t directionFlags[NUM_LEDS];
bool getPixelDirection( uint16_t i) {
return directionFlags[i];
void setPixelDirection( uint16_t i, bool dir) {
directionFlags[i] = dir;
#endif
#if BITS_PER_DIRECTION_FLAG == 1
// Compact (but more complicated) implementation of
// the directionFlags array, using just one BIT of RAM
// per pixel. This requires a bunch of bit wrangling,
// but conserves precious RAM. The cost is a few
// cycles and about 100 bytes of flash program memory.
uint8_t directionFlags[ (NUM_LEDS+7) / 8];
uint16_t index = i / 8;
uint8_t bitNum = i & 0x07;
// using Arduino 'bitRead' function; expanded code below
return bitRead( directionFlags[index], bitNum);
// uint8_t andMask = 1 << bitNum;
// return (directionFlags[index] & andMask) != 0;
// using Arduino 'bitWrite' function; expanded code below
bitWrite( directionFlags[index], bitNum, dir);
// uint8_t orMask = 1 << bitNum;
// uint8_t andMask = 255 - orMask;
// uint8_t value = directionFlags[index] & andMask;
// if( dir ) {
// value += orMask;
// directionFlags[index] = value;
#endif)
Here is the error I get now.
(Arduino: 1.6.3 (Windows 8.1), Board: "Adafruit Gemma 8MHz"
Build options changed, rebuilding all Sketch uses 5,450 bytes (102%) of program storage space. Maximum is 5,310 bytes. Global variables use 136 bytes of dynamic memory. processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it. at processing.app.debug.Compiler.size(Compiler.java:336) at processing.app.debug.Compiler.build(Compiler.java:119) at processing.app.Sketch.build(Sketch.java:1170) at processing.app.Sketch.build(Sketch.java:1143) at processing.app.Editor$BuildHandler.run(Editor.java:2016) at java.lang.Thread.run(Thread.java:745) Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
enabled in File > Preferences.)
Here is the sketch as from you’re the project post.
(#include "FastLED.h"
#define LED_PIN 9
#define NUM_LEDS 7
#define MASTER_BRIGHTNESS 18 // change this to change overall brightness
#define STARTING_BRIGHTNESS 128 // change this to change maximum brightness
#define FADE_IN_SPEED 5 // lower number fades in slower
#define FADE_OUT_SPEED 10 // higher number hangs around longer
#define DENSITY 255
delay(3000);
void loop()
//gPalette = RainbowColors_p;
//gPalette = HeatColors_p;
//gPalette = PartyColors_p;
//gPalette = CloudColors_p;
//gPalette = RainbowStripeColors_p;
colortwinkles();
FastLED.show();
FastLED.delay(70); // change this to change overall speed
if( !leds[pos]) {
} else {
return newcolor;
#endif
// if( dir ) {
// value += orMask;
#endif
C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:185:36: note: in expansion of macro 'ROR1' #define SCROR04(B, N) SCALE02(B,N) ROR1(B) CLC1 ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:308:27: note: in expansion of macro 'SCROR04' HI1 D1(1) QLO2(b2, 4) SCROR04(b0,2) D2(4) LO1 SCALE02(b0,3) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:177:47: error: impossible constraint in 'asm' #define CLC1 asm __volatile__("clc" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:185:44: note: in expansion of macro 'CLC1' #define SCROR04(B, N) SCALE02(B,N) ROR1(B) CLC1 ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:308:27: note: in expansion of macro 'SCROR04' HI1 D1(1) QLO2(b2, 4) SCROR04(b0,2) D2(4) LO1 SCALE02(b0,3) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:308:48: note: in expansion of macro 'LO1' HI1 D1(1) QLO2(b2, 4) SCROR04(b0,2) D2(4) LO1 SCALE02(b0,3) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:158:103: error: impossible constraint in 'asm' #define SCALE02(B, N) asm __volatile__("sbrc %[s0], " #N "\n\tadd %[" #B "], %[scale_base]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:308:52: note: in expansion of macro 'SCALE02' HI1 D1(1) QLO2(b2, 4) SCROR04(b0,2) D2(4) LO1 SCALE02(b0,3) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:148:110: error: impossible constraint in 'asm' #define HI1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[hi]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=hi; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:5: note: in expansion of macro 'HI1' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:69: error: impossible constraint in 'asm' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:71: note: in expansion of macro 'LO1' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:175:60: error: impossible constraint in 'asm' #define ROR1(B) asm __volatile__("ror %[" #B "]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:181:23: note: in expansion of macro 'ROR1' #define RORSC04(B, N) ROR1(B) CLC1 SCALE02(B, N) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:27: note: in expansion of macro 'RORSC04' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:177:47: error: impossible constraint in 'asm' #define CLC1 asm __volatile__("clc" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:181:31: note: in expansion of macro 'CLC1' #define RORSC04(B, N) ROR1(B) CLC1 SCALE02(B, N) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:27: note: in expansion of macro 'RORSC04' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:158:103: error: impossible constraint in 'asm' #define SCALE02(B, N) asm __volatile__("sbrc %[s0], " #N "\n\tadd %[" #B "], %[scale_base]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:181:36: note: in expansion of macro 'SCALE02' #define RORSC04(B, N) ROR1(B) CLC1 SCALE02(B, N) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:27: note: in expansion of macro 'RORSC04' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:48: note: in expansion of macro 'LO1' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:175:60: error: impossible constraint in 'asm' #define ROR1(B) asm __volatile__("ror %[" #B "]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:52: note: in expansion of macro 'ROR1' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:177:47: error: impossible constraint in 'asm' #define CLC1 asm __volatile__("clc" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:309:61: note: in expansion of macro 'CLC1' HI1 D1(1) QLO2(b2, 3) RORSC04(b0,4) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:148:110: error: impossible constraint in 'asm' #define HI1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[hi]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=hi; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:5: note: in expansion of macro 'HI1' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:69: error: impossible constraint in 'asm' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:71: note: in expansion of macro 'LO1' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:158:103: error: impossible constraint in 'asm' #define SCALE02(B, N) asm __volatile__("sbrc %[s0], " #N "\n\tadd %[" #B "], %[scale_base]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:185:23: note: in expansion of macro 'SCALE02' #define SCROR04(B, N) SCALE02(B,N) ROR1(B) CLC1 ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:27: note: in expansion of macro 'SCROR04' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:175:60: error: impossible constraint in 'asm' #define ROR1(B) asm __volatile__("ror %[" #B "]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:185:36: note: in expansion of macro 'ROR1' #define SCROR04(B, N) SCALE02(B,N) ROR1(B) CLC1 ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:27: note: in expansion of macro 'SCROR04' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:177:47: error: impossible constraint in 'asm' #define CLC1 asm __volatile__("clc" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:185:44: note: in expansion of macro 'CLC1' #define SCROR04(B, N) SCALE02(B,N) ROR1(B) CLC1 ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:27: note: in expansion of macro 'SCROR04' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^
C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:48: note: in expansion of macro 'LO1' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:158:103: error: impossible constraint in 'asm' #define SCALE02(B, N) asm __volatile__("sbrc %[s0], " #N "\n\tadd %[" #B "], %[scale_base]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:310:52: note: in expansion of macro 'SCALE02' HI1 D1(1) QLO2(b2, 2) SCROR04(b0,5) D2(4) LO1 SCALE02(b0,6) D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:148:110: error: impossible constraint in 'asm' #define HI1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[hi]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=hi; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:5: note: in expansion of macro 'HI1' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:69: error: impossible constraint in 'asm' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:71: note: in expansion of macro 'LO1' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:175:60: error: impossible constraint in 'asm' #define ROR1(B) asm __volatile__("ror %[" #B "]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:181:23: note: in expansion of macro 'ROR1' #define RORSC04(B, N) ROR1(B) CLC1 SCALE02(B, N) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:27: note: in expansion of macro 'RORSC04' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:177:47: error: impossible constraint in 'asm' #define CLC1 asm __volatile__("clc" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:181:31: note: in expansion of macro 'CLC1' #define RORSC04(B, N) ROR1(B) CLC1 SCALE02(B, N) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:27: note: in expansion of macro 'RORSC04' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:158:103: error: impossible constraint in 'asm' #define SCALE02(B, N) asm __volatile__("sbrc %[s0], " #N "\n\tadd %[" #B "], %[scale_base]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:181:36: note: in expansion of macro 'SCALE02' #define RORSC04(B, N) ROR1(B) CLC1 SCALE02(B, N) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:27: note: in expansion of macro 'RORSC04' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:48: note: in expansion of macro 'LO1' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:175:60: error: impossible constraint in 'asm' #define ROR1(B) asm __volatile__("ror %[" #B "]" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:52: note: in expansion of macro 'ROR1' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:177:47: error: impossible constraint in 'asm' #define CLC1 asm __volatile__("clc" ASM_VARS ); ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:311:61: note: in expansion of macro 'CLC1' HI1 D1(1) QLO2(b2, 1) RORSC04(b0,7) D2(4) LO1 ROR1(b0) CLC1 D3(2) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:148:110: error: impossible constraint in 'asm' #define HI1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[hi]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=hi; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:313:5: note: in expansion of macro 'HI1' HI1 D1(1) QLO2(b2, 0) D2(0) LO1 D3(0) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:69: error: impossible constraint in 'asm' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:313:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 0) D2(0) LO1 D3(0) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:152:71: note: in expansion of macro 'LO1' #define QLO2(B, N) asm __volatile__("sbrs %[" #B "], " #N ASM_VARS ); LO1; ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:313:15: note: in expansion of macro 'QLO2' HI1 D1(1) QLO2(b2, 0) D2(0) LO1 D3(0) ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:150:110: error: impossible constraint in 'asm' #define LO1 if((int)(FastPin<DATA_PIN>::port())-0x20 < 64) { asm __volatile__("out %[PORT], %[lo]" ASM_VARS ); } else { *FastPin<DATA_PIN>::port()=lo; } ^ C:\Program Files (x86)\arduino\libraries\FastLED/clockless_trinket.h:313:39: note: in expansion of macro 'LO1' HI1 D1(1) QLO2(b2, 0) D2(0) LO1 D3(0) ^ Error compiling.
