I installed Visual Studio 2013 with Visual Micro and the adafruit Arduino libraries and IDE to be able to program the Trinket Pro (in the correct order).
When I try to compile for the Trinket Pro there are some core libraries missing (SPI, WIRE, and more) and the compile fails.
When I try to compile for an Adruino board, the compile works, all libraries are found.
Looking at the libraries I see the adafruit but no SPI, WIRE, then when I look at the core Arduino libraries the missing libraries are installed.
Has anyone had these issues, how where they fixed?
Thank you,
Visual Micro Library Issues
- rdevries
- Libraries.jpg (38.68 KiB) Viewed 357 times
- Franklin97355
Re: Visual Micro Library Issues
SPI, Wire and others are core libraries supplied with the IDE and are not in the Adafruit libraries. Check your file settings to make sure you are looking in the correct place for libraries.
