Hi there, following much goggling and tutorials I've got my Adafruit 16-Channel 12-bit PWM hooked up to my rPi and some analogue 5050 strips, currently all playing nicely together as a prototype (in the end).
I'm now looking for somewhat more permanent connections for the PWM to the LED strip vs the jumpers currently in use, I'm thinking some sort of terminal block for the V+ row of each 4 channel group. Any ideas on where I could find something the right size or a better approach? (bearing in mind UK) thinking terminal blocks purely for ease of unscrewing and repositioning the cables running to the LED strips.
Cheers
PWM Connector Advice
- adafruit_support_bill
Re: PWM Connector Advice
You don't mention which version of the board you are using. From any of the boards, you can take V+ from anywhere on the servo headers or from the external power terminal. If you are using the HAT or Shield version, you can also take it from the 5v pads in the prototyping area. The prototyping area will let you mount whatever type of terminal block suits your purposes.
