Yea I did those steps, these are the outputs from doing them again:
pi@raspberrypi ~ $ sudo apt-get install python-smbus
Reading package lists... Done
Building dependency tree
Reading state information... Done
python-smbus is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
pi@raspberrypi ~ $ sudo apt-get install i2c-tools
i2c-tools is already the newest version.
I also went into raspiconfig again to check to make sure i2c was enabled but I couldn't find a way to check, so I did those steps again to enable it.
Installing software again.
pi@raspberrypi ~ $ git clone https://github.com/adafruit/Adafruit-Motor-HAT-Python-Library.git
Cloning into 'Adafruit-Motor-HAT-Python-Library'...
remote: Counting objects: 50, done.
remote: Total 50 (delta 0), reused 0 (delta 0), pack-reused 50
Unpacking objects: 100% (50/50), done.
pi@raspberrypi ~/Adafruit-Motor-HAT-Python-Library $ sudo apt-get install python-dev
python-dev is already the newest version.
pi@raspberrypi ~/Adafruit-Motor-HAT-Python-Library $ sudo python setup.py install
running install
Checking .pth file support in /usr/local/lib/python2.7/dist-packages/
/usr/bin/python -E -c pass
TEST PASSED: /usr/local/lib/python2.7/dist-packages/ appears to support .pth files
running bdist_egg
running egg_info
creating Adafruit_MotorHAT.egg-info
writing requirements to Adafruit_MotorHAT.egg-info/requires.txt
writing Adafruit_MotorHAT.egg-info/PKG-INFO
writing top-level names to Adafruit_MotorHAT.egg-info/top_level.txt
writing dependency_links to Adafruit_MotorHAT.egg-info/dependency_links.txt
writing manifest file 'Adafruit_MotorHAT.egg-info/SOURCES.txt'
reading manifest file 'Adafruit_MotorHAT.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/Adafruit_MotorHAT
copying Adafruit_MotorHAT/Adafruit_MotorHAT.py -> build/lib.linux-armv7l-2.7/Adafruit_MotorHAT
copying Adafruit_MotorHAT/Adafruit_I2C.py -> build/lib.linux-armv7l-2.7/Adafruit_MotorHAT
copying Adafruit_MotorHAT/__init__.py -> build/lib.linux-armv7l-2.7/Adafruit_MotorHAT
copying Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py -> build/lib.linux-armv7l-2.7/Adafruit_MotorHAT
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
creating build/bdist.linux-armv7l/egg/Adafruit_MotorHAT
copying build/lib.linux-armv7l-2.7/Adafruit_MotorHAT/Adafruit_MotorHAT.py -> build/bdist.linux-armv7l/egg/Adafruit_MotorHAT
copying build/lib.linux-armv7l-2.7/Adafruit_MotorHAT/Adafruit_I2C.py -> build/bdist.linux-armv7l/egg/Adafruit_MotorHAT
copying build/lib.linux-armv7l-2.7/Adafruit_MotorHAT/__init__.py -> build/bdist.linux-armv7l/egg/Adafruit_MotorHAT
copying build/lib.linux-armv7l-2.7/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py -> build/bdist.linux-armv7l/egg/Adafruit_MotorHAT
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_MotorHAT/Adafruit_MotorHAT.py to Adafruit_MotorHAT.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_MotorHAT/Adafruit_I2C.py to Adafruit_I2C.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_MotorHAT/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py to Adafruit_PWM_Servo_Driver.pyc
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_MotorHAT.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_MotorHAT.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_MotorHAT.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_MotorHAT.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_MotorHAT.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/Adafruit_MotorHAT-1.3.0-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing Adafruit_MotorHAT-1.3.0-py2.7.egg
removing '/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg' (and everything under it)
creating /usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg
Extracting Adafruit_MotorHAT-1.3.0-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adafruit-MotorHAT 1.3.0 is already the active version in easy-install.pth
Installed /usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg
Processing dependencies for Adafruit-MotorHAT==1.3.0
Searching for Adafruit-GPIO==0.9.3
Best match: Adafruit-GPIO 0.9.3
Processing Adafruit_GPIO-0.9.3-py2.7.egg
Adafruit-GPIO 0.9.3 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/Adafruit_GPIO-0.9.3-py2.7.egg
Searching for spidev==3.1
Best match: spidev 3.1
Processing spidev-3.1-py2.7-linux-armv7l.egg
spidev 3.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/spidev-3.1-py2.7-linux-armv7l.egg
Finished processing dependencies for Adafruit-MotorHAT==1.3.0
Again running my script I get this as output:
pi@raspberrypi ~/Adafruit-Motor-HAT-Python-Library/examples $ sudo python mytest.py
File "mytest.py", line 2, in <module>
from Adafruit_MotorHAT import Adafruit_MotorHAT, Adafruit_DCMotor
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg/Adafruit_MotorHAT/__init__.py", line 1, in <module>
from .Adafruit_MotorHAT import Adafruit_StepperMotor, Adafruit_DCMotor, Adafruit_MotorHAT
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_MotorHAT.py", line 3, in <module>
from Adafruit_PWM_Servo_Driver import PWM
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py", line 11, in <module>
class PWM :
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py", line 35, in PWM
general_call_i2c = Adafruit_I2C(0x00)
File "/usr/local/lib/python2.7/dist-packages/Adafruit_MotorHAT-1.3.0-py2.7.egg/Adafruit_MotorHAT/Adafruit_I2C.py", line 43, in __init__
self.bus = smbus.SMBus(busnum if busnum >= 0 else Adafruit_I2C.getPiI2CBusNumber())
IOError: [Errno 2] No such file or directory
