sequencer not working
Re: sequencer not working
Postby guest » Fri Jan 21, 2011 3:43 am
check your multimeter to see if its measuring right
measure a new 9v or 1.5v battery
what is the part number on ic20
what are the voltages on ic20
guest
Postby Mussi81 » Sat Jan 22, 2011 3:07 pm
guest wrote:check your multimeter to see if its measuring right
checked my meter ok on some batteries
the part number on ic20 is "ts7085"
i cant get the correct voltage on ic20 but i can get the correct voltages at j4!
the middle pad on ic20 might be have a bad connection, can i connect this to another point on the board?
Mussi81
Postby guest » Sat Jan 22, 2011 4:37 pm
that can go to any good ground point
you can tell the ground pins
by the little cross hairs that connect to the groundplane
also
turn the x0x power off
and measure the resistance between
ground on the mainbaoard and ioboard
it sounds like there is something flakey
its a bit strange that the voltage would go up on the mainboard though
although a bad ground on ic20 would do that
guest
Postby Mussi81 » Sat Jan 22, 2011 6:01 pm
guest wrote:that can go to any good ground point
also
sorry for my ignorance but how do i check the resistance?
Mussi81
Postby Mussi81 » Sat Jan 22, 2011 6:06 pm
also alot of the led's dont light up when the buttons are pressed
Mussi81
Postby guest » Sat Jan 22, 2011 6:53 pm
put your meter on resistance mode
its usually marked with an ohm symbol
turn the x0x off
put one probe on a ground point on the mainboard
put the other probe on a ground point on the ioboard
you can also check from the middle pin of ic20
to the ground on the ioboard
to see if its flakey
this is a likely cause of getting 6v on the mainboard
guest
Postby Mussi81 » Sat Jan 22, 2011 7:28 pm
guest wrote:put your meter on resistance mode
turn the x0x off
ok, i check from 1 of the switches tact switches to headphone jack and got 109.7k
and from the tack switch to the midde pin on ic 20 and got 15.83k
Mussi81
Postby guest » Sat Jan 22, 2011 7:49 pm
the tact switches arent grounded
use the negative pin of c102 on the mainboard
and the negative pin of c3 on the ioboard
and then check the middle pin of ic20
to the negative pin of c3 on the ioboard
guest
Postby Mussi81 » Sat Jan 22, 2011 7:57 pm
guest wrote:the tact switches arent grounded
c102 to c3 0.2
middle pin ic20 to c3 5.78
Mussi81
Postby guest » Sat Jan 22, 2011 8:17 pm
try clipping the middle pin of ic20
back to ground
and see if you get 5v on the mainboard again
if you are still getting 6v on the mainboard
disconnect the mainboard from the ioboard
until you have a steady 5v
as 6v can damage some of the parts
guest
Postby Mussi81 » Sun Jan 30, 2011 3:58 pm
guest wrote:try clipping the middle pin of ic20
back to ground
this is all sorted now, i have 5v again.
resoldered ic20 again and i went through the manual checked everything again. everything is good except c3 is giving me 13.42 which is a bit low. i dont know if that is relevant or not?!?
so i still have the same issue, i can hear the sounds when pressing buttons in keyboard mode for a few seconds then the volume fades down, also some of the leds do not work.
along the way i had problems with ic6, is there a way to check if this is all ok?? i have a scope just not sure what to check!
thanks in advance :)
Mussi81
Postby guest » Mon Jan 31, 2011 12:54 am
13v on c3 is plenty
in keyboard mode
the note should fade out after a few seconds
does it sound ok when you play a pattern
which leds do not work
guest
Postby Mussi81 » Mon Jan 31, 2011 4:50 pm
guest wrote:13v on c3 is plenty
in keyboard mode
when i turn the unit on lots dont work, from the keyboard top row, c# is the only working led. the bottom row g,b and c' are not working.
when i say the the volume fades, once its gone no sounds can be heard from any of the keys. i have to turn off and on again so i can hear the notes
Mussi81
Postby guest » Tue Feb 01, 2011 3:31 am
are you using a 9v AC wallwart
plug it in
and let the sound die out
and measure the 12v and 5.333v and 5v rails
make sure they are good
then do the headphone test on the vco and vcf
and see if there is still signal
if there is
put the x0x in keyboard mode
and measure the gate out
when you press a key
make sure it goes to 12v and back down to 0v
guest
Postby Mussi81 » Tue Feb 01, 2011 4:00 pm
guest wrote:are you using a 9v AC wallwart
yes
plug it in
all good
went through the manual again and test all ok with a scope
if there is
all the notes go between 0.44v and 11.52v when pressed
Mussi81
PreviousNext
Return to Making x0x
Users browsing this forum: No registered users and 4 guests
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
