Phone has no output but the Mix out works!
Postby tanta » Sun Sep 26, 2010 8:13 am
Hi
Just finish building the x0xb0x. The Phone Jack has no sound, but the mix out jack is working. I can't even hear a pop through speakers when the Phone jack socket plugged in (works on mix out). What should I check? Can someone please help. Thanks
Regards,
tanta
tanta
Re: Phone has no output but the Mix out works!
Postby guest » Sun Sep 26, 2010 9:11 am
check that j5 is orientated properly
measure the voltages on ic14
make sure there is 6v on pin7
listen for signal with a pair of headphones
on j5 on the mainboard
guest
Postby pcbatterij » Tue Feb 08, 2011 1:20 pm
Hey I have the same problem, did you find the solution?
can you also tell me what the values should be on J5?
cheers
pcbatterij
Return to Making x0x
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
