excellent
that helps a lot
put your scope on d37
either side is fine
and see if you get a pulse
when you trigger a note
if not
check the voltages on q38
guest wrote:excellent
that helps a lot
either side is fine
if not
guest wrote:place your scope on each pin of q38
and see what the waveforms look like
if the d37 point stays at 11v and doesnt change
then either q38 is bad
or there is short on r148 to ground
guest wrote:measure the resistance to ground
from both sides of r148
what are the voltages
on all pins of q38
both with and without a note being held
guest wrote:is d37 orientated properly
if it is
measure the resistance across it
in both directions
did you mean 6.73 or -6.73v
there are no negative voltages inside the x0x
guest wrote:the diode might be bad
it should have a higher resistance
in the backward direction
but check those voltages i mentioned
there shouldnt be any negative voltages
