sequencer not working
Re: sequencer not working
Postby guest » Wed Feb 02, 2011 2:04 am
excellent
that helps a lot
put your scope on d37
either side is fine
and see if you get a pulse
when you trigger a note
if not
check the voltages on q38
guest
Postby Mussi81 » Mon Feb 07, 2011 4:47 pm
guest wrote:excellent
that helps a lot
either side is fine
if not
there is no pulse at d37 no movement at all on the scope
i can get 11.78vdc at q38
Mussi81
Postby guest » Mon Feb 07, 2011 5:51 pm
place your scope on each pin of q38
and see what the waveforms look like
if the d37 point stays at 11v and doesnt change
then either q38 is bad
or there is short on r148 to ground
guest
Postby Mussi81 » Tue Feb 08, 2011 3:20 pm
guest wrote:place your scope on each pin of q38
nothing happened at q38 so i replaced it, still nothing happens
how do i sort r148. replace it?
Mussi81
Postby guest » Tue Feb 08, 2011 3:41 pm
measure the resistance to ground
from both sides of r148
what are the voltages
on all pins of q38
both with and without a note being held
guest
Postby Mussi81 » Tue Feb 08, 2011 4:18 pm
guest wrote:measure the resistance to ground
on all pins of q38
resistance 12.60k and fluctuates between 22k and 28k
if i clip the ground cable to the middle pin i get 11.80vdc note off and on
grounded to voltage regulator i get 11.80 on and off, - 6.73 on and off, 5.14 on and off
Mussi81
Postby guest » Tue Feb 08, 2011 4:40 pm
is d37 orientated properly
if it is
measure the resistance across it
in both directions
did you mean 6.73 or -6.73v
there are no negative voltages inside the x0x
guest
Postby guest » Tue Feb 08, 2011 4:47 pm
with the ground clipped to the voltage regulator
measure the voltage at the following points
both sides of c54
both sides of r148
both sides of r149
both sides of r150
both sides of r151
it shouldnt matter with note on or note off
as it seems to be doing the same thing either way
guest
Postby Mussi81 » Tue Feb 08, 2011 5:00 pm
guest wrote:is d37 orientated properly
if it is
in both directions
D37 is in correct way.
Resistance 27.8 and 254.5
Yes I did mean -6.73v
Mussi81
Postby guest » Tue Feb 08, 2011 5:19 pm
the diode might be bad
it should have a higher resistance
in the backward direction
but check those voltages i mentioned
there shouldnt be any negative voltages
guest
Postby Mussi81 » Tue Feb 08, 2011 6:10 pm
guest wrote:the diode might be bad
Because I have been moving the two boards about too much some of the cables have broken at the connection. I will have tO get some new cables before I continue as this has already happened :x those ribbon cables in the bom are to thin
Maybe that is why there is a negative voltage?
Mussi81
Postby Mussi81 » Tue Feb 08, 2011 6:13 pm
This project is becoming painful
Mussi81
Postby guest » Tue Feb 08, 2011 6:51 pm
the ribbon cables definitely arent good
for multiple opening and closings of the case
it will be worth it when its done
guest
Previous
Return to Making x0x
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
