Hello there forum! Maybe you can help me? I've done some circuit bending including an RX-17 but nothing like this x0xb0x.
I bought a kit through ebay from Technology Transplant, saying it was possible to follow the kit instructions at adafruit.
I started the power supply and had little to no issues. However, I did get readings that were a bit off and haven't been able to figure out what is wrong. All the IC's and resistors are in correct. I'm getting 10.8V on the wallwort. The diodes are all going to correct way and are the correct ones. From what I can tell the soldering seems alright but I think also that might be the weakest link here. Someone did use the multimeter on it not knowing anything and said there was a spark so I'm really worried that something might be fried but the readings at the end seem too close to make that an issue. It was unplugged at the time (I'm pretty sure) too so I think the spark might have just been from a capacitor.
Across C3 I am getting 5.0V DC and across C5 I am getting 14.2V DC.
I should be getting the same reading out both C3 and C5 which should be about 15V DC or higher.
I'm not sure what else to check for but voltages off the 6562 are:
1: 11.7V 2: 5.31V 3: 5.31V 4: -0V 5: 5.31V 6: 5.33V 7: 18.18V
I know the out voltage is supposed to be 5.333V but if I turn the trim pot all the way up it wavers between 5.0V and 5.3V.
Is this something I should be worried about? Does it sound like cold soldering joints? Is it possible that a resistor or capacitor was fried and still get that close?
Thank for your replies I hope I am on the right path.
