Led test help needed please with USBTiny
The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
Postby cornz » Wed Feb 23, 2011 1:33 pm
Ok, repaired the power supply section of the board, tested and have 3, 5,12 and 26v.
So, CPU is soldered in place with res and LED.
The downloaded firmware file is unpacked in c:\bubble
So, i run (as admin) a CMD , do the test: avrdude -c usbtiny -p m8 and the reponse is as it should be.
So then, clutching at straws, i tried avrdude -c usbtiny -p atmega88
Which gave:
So, then i tried make burn-fuse and as you can see, it didnt program. I think its the com4 part but how do i change it???
Thanks for any help..
cornz
Re: Led test help needed please with USBTiny
Postby cornz » Wed Feb 23, 2011 1:50 pm
Well, i decided to open the "makefile" file and look for the string com4, which i found and changed to com3, needless to say it still fails.
I feel pretty sure this is half the fault, how do i select the com port for programming it.
Cant understand how i can probe the chip though..
cornz
Postby Chankster » Wed Feb 23, 2011 2:22 pm
Looks like you installed an atmega88p but are specifying an atmega88
part
id = "m88p";
desc = "ATMEGA88P";
has_debugwire = yes;
flash_instr = 0xB6, 0x01, 0x11;
eeprom_instr = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
0x99, 0xF9, 0xBB, 0xAF;
stk500_devcode = 0x73;
# avr910_devcode = 0x;
signature = 0x1e 0x93 0x0f;
part
id = "m88";
desc = "ATMEGA88";
signature = 0x1e 0x93 0x0a;
http://svn.savannah.nongnu.org/viewvc/t ... iew=markup
"This is not my sig", it said. - I looked at it suspiciously; Who's sig was it, then?
Chankster
Postby cornz » Wed Feb 23, 2011 3:59 pm
Thanks for the bone..
Sadly, still doesnt seem to want to play.
I copied the conf files from the link into my avrdude directory, ran the make burn-fuse command and got an error about a "@" being an unknown charater at 595. So then i just copied the device id code from the at88p to the at88, which still gave an error...
Stuck and its getting late...
Any suggestions?
its passingt he connection test , thats whats odd...
cornz
Postby Chankster » Wed Feb 23, 2011 4:42 pm
What is the full string you are using to program and the full error that you are receiving?
Chankster
Postby cornz » Thu Feb 24, 2011 5:47 am
Ok, here are the steps taken so far and the results.
Right,Win7 ULT x64
USBtiny with 5.5 from here.
http://www.ladyada.net/make/usbtinyisp/download.html
I have used my USBtiny before to program my ice clock so im pretty sure its ok.
Download latest WinAVR from:
http://sourceforge.net/projects/winavr/ ... /20100110/
So, using the test procedure.
http://www.ladyada.net/make/usbtinyisp/avrdude.html
Suggests all works well.
Then, as an experiment i tried:
So, then i wondered what wouldhappen if i used -F, well, still suggests the programmer is working, but it still doesn't help.
So, back to the "make section of the WB website and programming the chip.
I've unzipped the firmware files for the WB and placed them into a folder.
C:\bubble
I then navigate to this directory and type make burn-fuse. The result is below:
Now, after having slept and had a think, i have a better grasp of what the problem is. Its that AVRDUDE (or "makefile") isnt configured properly to use a USBTiny...So, it means messing with something in AVRDUDE to make it realise that im using a USBTiny programmer. But i'm stuck now as im reading about compiling and source code and i havent got a clue.
Advice???
Thanks....
cornz
Postby cornz » Thu Feb 24, 2011 6:09 am
UPDATE:
After using this string:
C:\bubble>avrdude -c usbtiny -p atmega88 -F avrisp -u -U lfuse:w:0xe2:m -U hfuse
:w:0xd7:m
It appears i have been succsesful.
So....We shall see.....
cornz
Postby Chankster » Thu Feb 24, 2011 11:44 am
Good troubleshooting!
I would be cautious about overriding the Device Signature checks unless you are super sure. What I was referring to earlier was the message "Device signature = 0x1e930f" "Expected signature for ATMEGA88 is 1E 93 0A". Instead of specifying atmega88 you should use atmega88p which matches the device signature.
For future reference here's what you would need to change in the makefile:
Line 2: Change atmega88 to atmega88p (to match the part you selected)
Line 101: Change avrisp to usbtiny
Line 105: Change com4 to whatever com port your device is on
Chankster
Return to Wave Bubble
New Products [103]
LEDs[109]
Cables[61]
