give this a try
take a look at the second picture on this page
http://ladyada.net/make/x0xb0x/fab/ioboard/index.htmlat the bottom of the pcb
you will see a very thick trace
running the whole length of the pcb
you can also see a short bit that comes up
and goes to the usb section
first connecting c203
if you take a banned blade
and cut this trace as right before c203
so the long trace on the bottom is still good
but the short trace to the usb section is broken
you will remove the 5v supply from the usb
if you want in the future
you can resolder the break
