Xbee + OLED graphic display
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
Postby therenegademaster » Mon Mar 21, 2011 5:18 pm
I am working on building a pair of arduino-based devices which will send text messages to each other using xbee modules. (Like walkie talkies, only they'll send text messages back and forth).
I was originally going to use a 4x20 LCD screen, but the OLED graphic display looks like it would be much better in terms of power consumption, portability, and number of characters I could display. The one problem I'm concerned with is that both the Xbee and the OLED display use the Serial.print command to send messages. Is there a simple way I can use both of these devices and specify whether the 'Serial' commands should go to the display or the xbees?
therenegademaster
Re: Xbee + OLED graphic display
Postby franklin97355 » Mon Mar 21, 2011 9:18 pm
Check out "software serial" (library)
franklin97355
Postby therenegademaster » Tue Mar 22, 2011 7:45 pm
Cool- thanks!
therenegademaster
Return to XBee products from Adafruit
New Products [103]
LEDs[109]
Cables[61]
