usb device not recognized
Postby ofcsilencer » Tue Mar 29, 2011 6:33 pm
I purchased the Kit
i use windows
when plugging in the device i get "usb device not recognized" then the usb device manager window pops up and tells me its an unknown device.
if i try manually installing the driver it tells me "the specified location does not contain information about your hardware"
i do not get any lights on the unit.
i know i didn't do the greatest job soldering the 20pin socket, but it seems to be making contact. heres pictures of the unit.
ofcsilencer
Re: usb device not recognized
Postby ofcsilencer » Tue Mar 29, 2011 6:35 pm
picture 1
ofcsilencer
Postby ofcsilencer » Tue Mar 29, 2011 6:39 pm
picture 2
ofcsilencer
Postby ofcsilencer » Tue Mar 29, 2011 6:40 pm
picture 3
ofcsilencer
Postby ofcsilencer » Tue Mar 29, 2011 6:42 pm
picture 4
ofcsilencer
Postby ofcsilencer » Tue Mar 29, 2011 6:43 pm
picture 5
ofcsilencer
Postby ofcsilencer » Tue Mar 29, 2011 6:44 pm
picture 6
ofcsilencer
Postby ofcsilencer » Tue Mar 29, 2011 6:45 pm
picture 7
ofcsilencer
Postby ofcsilencer » Tue Mar 29, 2011 6:46 pm
picture 8
ofcsilencer
Postby adafruit » Fri Apr 01, 2011 3:16 pm
email support@adafruit asking for a new usbtinyisp chip
Postby petrut_m » Fri Apr 29, 2011 7:37 am
Same problem only thing is its not a kit it's built from scratch and the firmware on the attiny2313 is burned with a parallel port programmer (avr "bsd") with avr dude . When burning the firmware everything goes ok but when I plug the attiny on the usbisp board and plug it in the usb I get one short flash of the red led and a "USB device not recognized" error mesage in windows.Could you give me a step by step guide to burning the firmware correctly? Which is the correct firmware file ?
petrut_m
Postby petrut_m » Fri Apr 29, 2011 9:37 am
Got it working!
I was using the right file "/spi/main.hex" but in the circuit I changed the type of oscillator from a ceramic to a crystal . After reading the datasheet I changed the fuses to "-U lfuse:w:0xff:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m" in avrdude and it worked. If you need a fuse calculator: http://www.engbedded.com/fusecalc
I added 22pF loading capacitors for the crystal just in case.
petrut_m
Return to USBtinyISP
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
