Solar LiPo charging
Solar LiPo charging
Postby Exogenous » Wed Aug 11, 2010 3:37 pm
The entry on the solar mintyboost mentions reducing the LiPo charging current if the smaller solar panel is used in order to "keep the lipoly charger from trying to draw too much current from the panel." I assume this is to avoid a voltage drop from the solar panel.
It would be pretty neat to adapt the charging circuit to automatically regulate the output current on the basis of the input voltage to get maximum charging ability, and also to allow a fast charge when connected to USB power.
Then again, perhaps this isn't needed - I ought to measure the voltage produced under different load and solar conditions. I don't know how quickly performance would deteriorate under load, but the bigger panel is nominally 6V at 330 mA so it seems it ought to be able to muster 3.75V (minimum required for the charge controller) at a somewhat higher load under reasonable lighting conditions.
Or maybe a potentiometer for R4 will suffice...
Exogenous
Re: Solar LiPo charging
Postby Oby One » Mon Jan 10, 2011 8:30 am
I bought the USB LiIon/LiPoly charger - v1.1 http://www.adafruit.com/index.php?main_ ... cts_id=259
Before I install it to my mintyboost .. I have read something about LiPo charghing on wiki: http://en.wikipedia.org/wiki/Lithium_io ... er_battery
During discharge on load, the load has to be removed as soon as the voltage drops below approximately 3.0 V per cell (used in a series combination), or else the battery will subsequently no longer accept a full charge and may experience problems holding voltage under load.
From the tests that I have done so far with my mintyboost... I noticed that it will not stop discharging the battery ....so I am now asking how can I prevent the damage to my lipo battery ... by preventing a discharge bellow 3.0 V ?
Oby One
Postby adafruit » Mon Jan 10, 2011 1:11 pm
all the lipos we sell have a protection circuit, they will not allow it to be discharged past 3v for safety
Postby Oby One » Mon Jan 10, 2011 3:52 pm
Yes.. but you said that there is a physical connection between the battery in and battery out ports.... so there is NOTHING preventing the mintyboost to get all the juice from the battery.
Oby One
Postby adafruit_support_bill » Mon Jan 10, 2011 4:04 pm
Unless, as Adfruit said, the LiPo has a protection circuit in it. From the product page: http://www.adafruit.com/index.php?main_page=product_info&cPath=44&products_id=258
The protection circuitry keeps the battery voltage from going to high (over-charging) or low (over-use)
Postby Oby One » Mon Jan 10, 2011 4:19 pm
The protection circuitry keeps the battery voltage from going to high (over-charging) or low (over-use) which means that the battery will cut-out when completely dead.
Aaaa I got it now.. the battery itself has the protection circuit.
Much more clear now.... thanks :)
However, even with this protection it is very important that you only use a LiIon/LiPoly constant-voltage/constant-current charger to recharge them and at a rate of 500mA or less
Hmm.. another question
Can I use a li-ion battery with my lipo charger?
They have similar voltage characteristics and I don't see a reason why it shouldn't work.
Oby One
Postby adafruit_support_bill » Mon Jan 10, 2011 5:06 pm
The Adafruit charger is rated for both LiIon and LiPo. But not all cells are created equal. Make sure you find one with the built in protection circuit.
Postby Oby One » Thu Mar 17, 2011 3:25 pm
I have another question for this USB LiIon/LiPoly charger - v1.1 http://www.adafruit.com/index.php?main_ ... cts_id=259
I want to put a 1000k rezistor so I can boost charging to 1Amp.
Do I have to remove the existing R4 rezistor.... when I install the new one?
Oby One
Postby Oby One » Sat Mar 19, 2011 5:17 am
Well ?
Oby One
Postby adafruit_support_bill » Sat Mar 19, 2011 6:56 am
You can remove it, or install another one in parallel to create the equivalent resistance.
Postby wdmarto » Thu Mar 31, 2011 7:29 am
I made solar(small)/lipo/minty exactly like you said and it works!
But, my solar do not charge my battery (medium 1300mAh), even after a full sunny day.
When I charge it with my computer, all is fine and the led Done is on. Immediately after that, I plug my solar panel in, the led Done becomes off and it charge again.
What can I do to solve that?
wdmarto
Postby adafruit_support_bill » Thu Mar 31, 2011 8:28 am
Can you post a photo showing all of your connections?
Postby wdmarto » Thu Mar 31, 2011 9:23 am
Here they are
wdmarto
Postby adafruit_support_bill » Thu Mar 31, 2011 9:30 am
What voltage do you measure from the solar panel when connected as shown?
What voltage do you measure when it is not connected to the charger?
Is your solar panel outside in full sun? Windows (especially modern "Hi-E" windows) reduce the available solar energy by quite a bit.
Next
Return to MintyBoost
New Products [102]
LEDs[109]
Cables[60]
