ILI9325 TFTLCD
ILI9325 TFTLCD
Postby EX-RIDER » Sat Apr 02, 2011 7:21 pm
I am completely new to all of this but I am having a blast. I am using the UNO along with the TFTLCD files provided by Adafruit and company and it is working really well. My question is in regards to the Data pins. Am I stuck with using pins 2-9 or can I shift them to 3-10? I am using a hall effect sensor and I really need pin 2 for its interrupt capability or I think I do anyways. Any suggestions?
EX-RIDER
Re: ILI9325 TFTLCD
Postby adafruit_support_bill » Sun Apr 03, 2011 4:54 am
You should be able to re-map these to different pins.
Re: ILI9325 TFTLCD
Postby EX-RIDER » Sun Apr 03, 2011 5:51 am
Your right and thank you for responding...thats what I was hoping to do but I unfortunately don't understand the TFTLCD.h file completely. Any suggestions? Hopefully a point in the right direction can get me going. Thank you!
EX-RIDER
Re: ILI9325 TFTLCD
Postby adafruit_support_bill » Sun Apr 03, 2011 6:30 am
The pin definitions are in the TFTLCD.CPP file. Note that the pins are defined in terms of the native ATMEGA ports, not the more familiar Arduino pin numbers.
http://www.arduino.cc/en/Reference/PortManipulation
Re: ILI9325 TFTLCD
Postby EX-RIDER » Sun Apr 03, 2011 6:34 am
AHHH... That makes more sense. Thank you for your help. I think I got it now.
EX-RIDER
Re: ILI9325 TFTLCD
Postby adafruit » Tue Apr 05, 2011 12:10 pm
look for this
// for the breakout board tutorial, two ports are used :/
#define DATAPORT1 PORTD
#define DATAPIN1 PIND
#define DATADDR1 DDRD
#define DATAPORT2 PORTB
#define DATAPIN2 PINB
#define DATADDR2 DDRB
#define DATA1_MASK 0xFC // top 6 bits
#define DATA2_MASK 0x03 // bottom 2 bits
you will want to change the MASK
remember that both MASKs together MUST cover all the pins from 0-7 so basically "DATA1_MASK | DATA2_MASK" must be 0xFF
New Products [105]
Components & Parts[70]
LEDs[111]
Cables[61]
