SSD1306
SSD1306
Postby songlight » Tue Apr 26, 2011 10:42 am
I would like to see how to connect the ssd1306 to the Arduino without the level shifter. Can someone show me how to hookit up?
Thanks.
songlight
Re: SSD1306
Postby adafruit » Tue Apr 26, 2011 12:50 pm
you must use a level shifter for Arduinos or it will damage the oled
Re: SSD1306
Postby songlight » Tue Apr 26, 2011 8:07 pm
adafruit wrote:you must use a level shifter for Arduinos or it will damage the oled
Thanks for the reply. I thought you could use the 3.3 volt output on the Arduino for the oled.
Can you explain?
songlight
Re: SSD1306
Postby Stephanie » Tue Apr 26, 2011 9:18 pm
You could use the 3.3v output to power the OLED but the SPI signals on the Arduino will still be at the full 5 volts which is too much for the OLED display. The purpose of the level shifter is that it reduces voltage on all the signal lines to 3.3v, not just the source voltage.
If you really don't want to use the level shifter, then you can mod your Arduino so the whole thing runs at 3.3v - and coincidentally LadyAda has a tutorial for this: http://www.ladyada.net/library/arduino/3v3_arduino.html
Cheers!
Stephanie
Re: SSD1306
Postby songlight » Wed Apr 27, 2011 12:32 pm
Stephanie wrote:You could use the 3.3v output to power the OLED but the SPI signals on the Arduino will still be at the full 5 volts which is too much for the OLED display. The purpose of the level shifter is that it reduces voltage on all the signal lines to 3.3v, not just the source voltage.
Cheers!
That explains it very well. OK so now I have it all hooked up with 3.3v. Is the screen supposed to light up when power is applied? Mine does not. Also, I have tried to run the software but it will not run. Other programs run ok. Any suggestions?
I appreciate your help.
songlight
Re: SSD1306
Postby adafruit » Thu Apr 28, 2011 12:11 pm
no, it must be driven from the arduino to display anything
follow our tutorial to use the display
http://ladyada.net/products/oled12864/
Re: SSD1306
Postby songlight » Thu Apr 28, 2011 4:22 pm
adafruit wrote:no, it must be driven from the arduino to display anything
I am driving everything from 3.3 volts off the Arduino nano but I get nothing on the screen. Also the software demo program you list will not load as it says there is an error. I don't know what to do next.
songlight
Re: SSD1306
Postby adafruit » Thu Apr 28, 2011 6:14 pm
you need to provide us more details and/or photos
Re: SSD1306
Postby songlight » Thu Apr 28, 2011 8:52 pm
adafruit wrote:you need to provide us more details and/or photos
How can I send you photos? What do you need to know that can help you to help me?
I have hooked up the oled as perscribed by the illustrations and have downloaded the software program. Is there some trouble shooting help available?
songlight
Re: SSD1306
Postby adafruit_support_bill » Fri Apr 29, 2011 4:55 am
The best way for us to help troubleshoot is for us to have a look at your setup.
There is an "Upload Attachment" tab just below the messager editing window. You can add photos to your message with that.
Re: SSD1306
Postby songlight » Fri Apr 29, 2011 9:55 am
arduwino wrote:The best way for us to help troubleshoot is for us to have a look at your setup.
sdd setup.jpg (508.88 KiB) Viewed 2536 times
Here is my setup. I hope this helps.
songlight
Re: SSD1306
Postby adafruit » Fri Apr 29, 2011 2:47 pm
check your wiring, remove any extra wires and use shorter ones so that it matches the images on the site. the oleds are tested so its probably a wiring issue
Re: SSD1306
Postby Stephanie » Fri Apr 29, 2011 4:54 pm
songlight wrote:I am driving everything from 3.3 volts off the Arduino nano but I get nothing on the screen. Also the software demo program you list will not load as it says there is an error. I don't know what to do next.
Just my 2cents but you mentioned you got an error when you tried the demo program, but you didn't say what the error was. Can you elaborate on the error message?
Also, if you couldn't get the example sketch to run, how are you testing the screen? What sketch are you using?
Stephanie
Re: SSD1306
Postby songlight » Sun May 01, 2011 11:54 am
Here is another pic more clearly of my set up.
A clearer picture
songlight
Re: SSD1306
Postby Stephanie » Sun May 01, 2011 12:35 pm
The OLED screens don't light up just from having power applied. They have no backlight, it's the idividual pixels themselves which provide their own illumination. So until the screen is given something to display, it will most likely appear to be completely 'off'. This kind of threw me at first too - unlike eg. the 16x2 character displays where just giving them power will show you some life, with the OLEDs it basically goes all or nothing. That is, either it works fine, or it seems dead.
Are you still getting errors when you try running the demo sketch?
Stephanie
Next
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 6 guests
New Products [103]
LEDs[109]
Cables[61]
