Comunication between 1 PC and 1 arduino via another adruino
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
Postby ygreq » Mon May 02, 2011 11:44 am
Hi folks,
The internet is full of examples where you have one Xbee connected directly to the computer another one connected to an arduino.
What I haven't found is a PC communicating with an arduino via another arduino, all through Xbee. Like in the following example:
Sensor - > Arduino -> Xbee ---> Xbee -> Arduino -> PC.
Thus we need the SoftwareSerial library or an Arduino Mega which I happen to have.
The problem is I am having difficulties playing with serial3 (for example). I admit I am a bit of a novice.
Is anyone willing to help with some code?
Thank you very much,
ygreq
ygreq
Re: Comunication between 1 PC and 1 arduino via another adruino
Postby ygreq » Mon May 02, 2011 12:28 pm
Ok! Here goes!
I have a Humidity and Temperature sensor from seeedstudio (http://www.seeedstudio.com/depot/electr ... d33d7b2a74) that is connected to a Seeduino Stalker with an Xbee module stuck into it. As I need to process some info coming in from the sensor before sending it via Xbee, I actually think I need the Arduino (instead of opting for the Xbee Adaptor).
On the other module I now realize I could use an Xbee Adapter without the arduino to connect to a PC running Max 5. But if I were to use an Arduino to get info coming through Xbee into the PC, I guess I would have to use Arduino Mega or NewSoftSerial library to connect my Xbee as the "normal" serial is occupied with communicating with the PC, right?
I looked at some examples on the net but it doesn't help!
This is the code for the HT Sensor which in the end sends info through serial (which I guess the Xbee connected to it should send). I don't know how the code for the Arduino connected to the computer should be! :( I would like to grab it from Xbee serial and send it to the PC
Thank you so much,
ygreq
[EDIT moderator - use code block]
#define DHT11_PIN 0      // ADC0
byte read_dht11_dat()
  byte i = 0;
  byte result=0;
  for(i=0; i< 8; i++){
    while(!(PINC & _BV(DHT11_PIN)));  // wait for 50us
    delayMicroseconds(30);
    if(PINC & _BV(DHT11_PIN))
      result |=(1<<(7-i));
    while((PINC & _BV(DHT11_PIN)));  // wait '1' finish
  return result;
void setup()
  DDRC |= _BV(DHT11_PIN);
  PORTC |= _BV(DHT11_PIN);
  Serial.begin(9600);
  Serial.println("Ready");
void loop()
  byte dht11_dat[5];
  byte dht11_in;
  byte i;
  // start condition
  // 1. pull-down i/o pin from 18ms
  PORTC &= ~_BV(DHT11_PIN);
  delay(18);
  delayMicroseconds(40);
  DDRC &= ~_BV(DHT11_PIN);
  dht11_in = PINC & _BV(DHT11_PIN);
  if(dht11_in){
    Serial.println("dht11 start condition 1 not met");
    return;
  delayMicroseconds(80);
  if(!dht11_in){
    Serial.println("dht11 start condition 2 not met");
    return;
  // now ready for data reception
  for (i=0; i<5; i++)
    dht11_dat[i] = read_dht11_dat();
  byte dht11_check_sum = dht11_dat[0]+dht11_dat[1]+dht11_dat[2]+dht11_dat[3];
  // check check_sum
  if(dht11_dat[4]!= dht11_check_sum)
    Serial.println("DHT11 checksum error");
  Serial.print("humidity = ");
  Serial.print(dht11_dat[0], DEC);
  Serial.print(".");
  Serial.print(dht11_dat[1], DEC);
  Serial.print("%  ");
  Serial.print("temperature = ");
  Serial.print(dht11_dat[2], DEC);
  Serial.print(".");
  Serial.print(dht11_dat[3], DEC);
  Serial.println("C  ");
  delay(2000);
ygreq
Postby adafruit_support_bill » Mon May 02, 2011 4:19 pm
Using NewSoftSerial is very much like using Serial. You just need to define a transmit and receive pin for each additional 'soft' serial port. Check this site for details: http://arduiniana.org/libraries/NewSoftSerial/
Return to XBee products from Adafruit
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
