5W solar panel / higher capacity LiPo for Mighty Minty Boost
Ideas and questions about MintyBoost kits
Postby soccerdude71 » Tue Jun 07, 2011 8:20 pm
I would like to try and use a 6v 5W panel for my MMB so that it charges faster. Suggestions for R4? Or anything else?? :)
Also, any thoughts on using the higher capacity LiPo? I think it is 2200Mah... Would it work with my suggested setup? Any issues with the MMB's ability to charge it? will it fit in my altoids case?
George
soccerdude71
Re: 5W solar panel / higher capacity LiPo for Mighty Minty Boost
Postby adafruit » Tue Jun 07, 2011 10:39 pm
the mintyboost doesnt care what kind of lipo is attached
as for the solar panel, we'll have a specialized solar charger that should greatly increase the charge rate. it will be released in a week or two, but we have no other details to release until then
Postby soccerdude71 » Tue Jun 07, 2011 11:36 pm
Thanks for your reply. I will look into this when it is released. In the meantime, what you you suggest for R4 on my existing unit with the 5w panel? And do you think the 2200 or 2700mah battery will fit in a altoids tin?
G
soccerdude71
Postby adafruit_support_bill » Wed Jun 08, 2011 5:22 am
I don't have a tin handy to check, but the cell dimensions are on the "technical details" tab here:
http://www.adafruit.com/products/328
Postby soccerdude71 » Wed Jun 08, 2011 11:48 am
It does not fit, but thanks for your reply. I found a better option anyhow ;)
http://www.batteryjunction.com/tenergy-37-6600-pcb.html
soccerdude71
Postby soccerdude71 » Fri Jun 17, 2011 3:14 pm
adafruit wrote:the mintyboost doesnt care what kind of lipo is attached
What is the status of this? Is it available yet?
Thanks!!
G
soccerdude71
Postby adafruit » Fri Jun 17, 2011 3:16 pm
No, there is no ETA at this time. we will announce it on the blog and post here when its ready
Postby j_jamesk » Tue Jun 28, 2011 1:29 am
Hi adafruit,
any news on the solar charger? cant wait to check it out.
James
j_jamesk
Postby adafruit » Tue Jun 28, 2011 6:01 pm
we are wrapping up assembly, we hope to have it in the shop this week if nothing goes wrong :)
Postby adafruit » Fri Jul 01, 2011 9:28 pm
Hi adafruit,
James
good news, we got a bunch of chargers tested and made, we did try one with a 6V 3W panel but dont have a larger one. we'd like to hear if it works with your big panel!
Postby soccerdude71 » Sat Jul 02, 2011 12:31 pm
Good news.... Where can I find the charger to view specs and order?
soccerdude71
Return to MintyBoost
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
