please help! ic20 getting hot! SOLVED!!!
Re: please help! ic20 getting hot! SOLVED!!!
Postby guest » Tue Jun 07, 2011 9:16 pm
since it is passing data
the serial in and serial out must be working
and the clock must also be working
so that only leaves the ledlatch pin
measure the resistance from pin12
to pin12 on one of the other 74hc595s
guest
Postby tupinamba » Wed Jun 08, 2011 12:37 pm
I think you have it right and we are getting close...
Resistance on pin 12 between other 74HC595 ICs is 0
Resistance between IC4 pin 12 and other 74HC595 pins 12 is 1
... What do I do ? Connect IC4 pin 12 to another pin 12 from another IC ?
tupinamba
Postby guest » Wed Jun 08, 2011 12:42 pm
you can solder a jumper wire
and see if it fixes it
guest
Postby tupinamba » Wed Jun 08, 2011 5:52 pm
I put a jumper wire between IC4 pin12 and IC5 pin 12.
Tempo, "C", "run", "next", steps 1 et 2 leds are working. That's great ! But...
"prev" and "chain" leds still not working;
Steps 4, 5 and 6 leds not working although they were working before... That's strange, isn't it ?
tupinamba
Postby SubStyler » Wed Jun 08, 2011 6:43 pm
hi tupinamba,
you told me that you have to desolder IC4 after it was soldered backwards.
please check all the traces around IC4, maybe there are one or more broken trace on the PCB from desoldering?
cheers
Sub
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
SubStyler
Postby guest » Wed Jun 08, 2011 11:19 pm
prev usually doesnt light up
perhaps in pattern edit mode
remove the jumper
and see if 4 5 and 6 come back to life
if they do not
then start checking the chip they are connected to
to see if its outputting 5v
guest
Postby tupinamba » Thu Jun 09, 2011 12:52 pm
OK it almost entirely solved and I can fully use this great instrument at last !
Remaining dead leds were due to... absence of resistor (I forgot 2 of them while changing from 1k to 10k :oops: ) and bad solder joints. I was even able to remove the jumper wire as the extra solder made the connection effective again.
There is only one thing remaining but it is far from vital :
When I power on the x0xb0x, "prev" and "next" leds are not lit. IC4 pins 3 ("prev" led) and 4 ("next" led) provide 0v.
But if I press "next" in Pattern Edit Mode then "next" led light up and stays this was (5v on IC4 pin 4).
And if I press "prev", nothing happens, and "next" led is still on. IC4 pin 3 never provides 5v when "prev" pressed.
I checked connections between IC4 pin 4, resistor and led, and between led and ground.
It tested the led which is working.
Weird, isn't it ?
Anyway, thanks a lot for your help, I would never have done it without it ! Now my x0xb0x is starting to play with my sequencer and my MB6582 and I think they get along pretty well... :wink:
tupinamba
Postby guest » Thu Jun 09, 2011 1:12 pm
the prev button may not light up
and i think the next button is supposed to stay on
so it sounds like its working correctly
congrats
guest
Postby tupinamba » Thu Jun 09, 2011 4:08 pm
Great ! Thanks again !
tupinamba
Postby Chris72160 » Tue Jun 18, 2013 12:55 pm
guest wrote:a bad usb chip
would give wrong readings on pin1 and pin2 of j3
may anyone tell me about "right readings" on pin1 and pin2 of j3?
How do you check the FT232BL when you have no connection to the computer?
Greetz Chris
Chris72160
Previous
Return to Making x0x
Users browsing this forum: No registered users and 4 guests
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
