hello everyone. I have a problem, which has happened twice so far, and i really dont want it to happen again if it can be avoided. That is, I spent the last 6 months or so practicing to introduce my xoxbox as a 3rd sound source while i'm djing(the other 2 sources being record players).I bought a soundbite micro (sampler) which converts the audio signal into midi which in turn syncs the xoxbox up to the same beat as the records. sounds great, that phatt acid sound incorporated into what i'm playing is perfect. however....i've only done this three times in front of an audience, and 2 of those times, the xoxbox shat itself, had a mind of its own,. would start sparatically, and stop randomly. I thought it might be the sampler playing up, that that was working fine. Afterwards i reloaded the firmware...bingo!!!, worked like a dream, so i can safely assume the firmware is instable. the question is, is there a way to stabilise the firmware. I really dont want to have to reload it everytime i play. The xoxbox i got 2nd hand, but the processor i then bought new from xoxboxshop in germany for excatly that reason, that it would be safe and reliable. the xoxbox did fall from about 1 metre high once (ok, twice, and that was between the 2 times it didnt work) and i had to replace the (78x05) 5V voltage regulator, but aprt from that, no damage.
any suggestions???
