serial port fail on Mac OS
SpokePOV kit for bikes
Postby ajerschow » Mon Jun 20, 2011 8:30 pm
Serial dongle does not work on Mac OS 10.5.8.
Using USB to serial cable and the serial dongle that came with SpokePOV. Using driver osx-pl2303-0.3.1-10.4-universal
(from here http://sourceforge.net/projects/osx-pl2 ... g/download).
Serial port appears under /dev/cu.PL2303-00001004 but no connection can be made with a terminal program (e.g. 'screen'), or with SpokePOV.
Any ideas about how this could be solved?
(also, could you post instructions for the proper way to test voltages on the dongle?)
Thank you
ajerschow
Re: serial port fail on Mac OS
Postby adafruit_support_bill » Tue Jun 21, 2011 5:40 am
The serial dongle is all passive components, so there is not much that can go wrong with it.
Post some photos of the boards (dongle and spokePOV) and we'll have a look for any assembly problems.
Postby ajerschow » Tue Jun 21, 2011 9:31 pm
Please find photos attached. Any advice is appreciated.
ajerschow
Postby adafruit_support_bill » Wed Jun 22, 2011 4:11 am
The dongle assembly looks fine. Do you have photos of the spokePOV?
Also, from the project page:
Important Note: under MacOS X, using a USB/serial adapter, sometimes there are multiple names for one port (/dev/cu.KeySerial1 and /dev/cu.USA19H1b1P1.1 for example. Try both! I've found they act differently and get better reliability with some over others!
Postby ajerschow » Wed Jun 22, 2011 6:00 am
Only one port is seen, /dev/cu.PL2303-00001004.
Attached are two more pictures of the SpokePOV for two units. They work fine with the default image, but as I mentioned the serial connection cannot be established.
ajerschow
Postby adafruit_support_bill » Wed Jun 22, 2011 6:17 am
I don't see any assembly problems there.
Are you able to open the COM port at all?
Postby ajerschow » Wed Jun 22, 2011 6:21 am
Under Mac OS, connection fails. Also a terminal program doesn't show any communication.
On a laptop PC, using also the USB-to-serial connector and the appropriate prolific driver it doesn't work either. Windows sees it as COM5 but doesn't connect via SpokePOV (I don't have a PC with a dedicated COM port).
ajerschow
Postby adafruit_support_bill » Wed Jun 22, 2011 7:35 am
On the PC, have you tried increasing the delay as described here? (about 1/4 down): http://www.ladyada.net/make/spokepov/software.html
Postby ajerschow » Wed Jun 22, 2011 11:52 am
Yes, tried up to 10,000. Did not help
ajerschow
Postby adafruit_support_bill » Wed Jun 22, 2011 1:18 pm
Does the USB/Serial + Dongle combination pass the "Test Port" test? (with no connection to the SopkePOV)
Postby ajerschow » Wed Jun 22, 2011 1:41 pm
No, does not pass Test Port (neither connected nor disconnected to SpokePOV)
ajerschow
Postby adafruit_support_bill » Wed Jun 22, 2011 1:50 pm
Does it give any meaningful error message or reason for failure?
I would suspect the USB/Serial cable is at fault. There just isn't much to the dongle itself and your soldering looks just fine.
Postby adafruit » Wed Jun 22, 2011 2:44 pm
also try v1.2 of the spokepov software. something changed recently in the mac os
Postby ajerschow » Wed Jun 22, 2011 9:37 pm
Indeed, using v. 1.2 helped. I can now run the serial port test with this version. All voltages are fine. However, when attempting to write to SpokePOV I get a fail. Any suggestions? (It seems that in v. 1.2 one cannot adjust the serial port delay?)
ajerschow
Postby adafruit » Thu Jun 23, 2011 2:53 pm
Hrm, something changed in the latest mac os x. we're going to try to fix v1.4 but it may be a week or two because we lost our development system and have to reinstall it. can you use windows in the meantime?
Next
Return to SpokePOV
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
