Solar Minty + DHT22 + Waterproof DS18B20 + PH Probe
Postby andyx » Sat Jul 09, 2011 4:38 pm
Solar powered Temperature corrected PH meter with Ambient Temperature and Humidity.
Display Shows Outside Temp and Humidity on top with PH and Water temp on bottom.
What is better than an Arduino? An Arduino with a laser!
andyx
Re: Solar Minty + DHT22 + Waterproof DS18B20 + PH Probe
Postby adafruit » Sat Jul 09, 2011 7:57 pm
Intense! do you have a writeup, diagrams or code? would be an awesome example to show people what can be done with arduino!
Postby andyx » Sat Jul 09, 2011 8:15 pm
I'll write something up with more info about it.
andyx
Postby andyx » Sun Jul 10, 2011 5:21 pm
This is a work in progress project which uses a Solar charging MintyBoost to power an Arduino with a Proto Screw Shield on it. Attached is a 2X16 LCD using the I2C Backpack, a DHT22 Temperature and Humidity Sensor, a Waterproof DS18B20 Sensor and a 5V analog PH Probe/Adapter.
Sketch combining DHT22, DS18B20 OneWire, LCD I2C and Analog PH 5V
Nothing very creative, but they all coexist no problem.
Make sure you visit each of these sensor's tutorials and get the required libraries.
#include <Wire.h>
#include <LiquidCrystal.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include "DHT.h"
#define DHTPIN 11
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
#define ONE_WIRE_BUS 10
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int sensorPinPH = A0;
LiquidCrystal lcd(0);
  dht.begin();
  lcd.begin(16, 2);
  lcd.setBacklight(HIGH);
  lcd.setCursor(8, 0);
  sensors.begin();
  float h = dht.readHumidity();
  float t = (dht.readTemperature()*9.0/5.0)+32.0;
  float sensorValue = 0;
  lcd.setCursor(0, 0);
  lcd.print(t);
  lcd.print(h);
  lcd.setCursor(0, 1);
  sensors.requestTemperatures();
  sensorValue = 7.0 - (2.5 - analogRead(sensorPinPH) / 204.8) / (0.257179 + 0.000941468 * sensors.getTempCByIndex(0));
  lcd.print(sensorValue);
  lcd.setCursor(8, 1);
  lcd.print((sensors.getTempCByIndex(0)*9.0/5.0)+32.0);
  delay(500);
andyx
Postby adafruit » Mon Jul 11, 2011 1:08 pm
nice work! we'll post this up on our blog!
Postby senojcet » Mon Jul 11, 2011 2:29 pm
What pH probe did you use? What is the BNC connector adapter board that you used? Thanks!
senojcet
Postby andyx » Mon Jul 11, 2011 8:44 pm
The adapter is a 1130 - pH/ORP Adapter from Phidgets.
The probe is a 3550 - ASP200-2-1M-BNC pH Lab Electrode.
Note that when using this sensor, formulas shown in the manual, need to be tweaked a bit. They use a 1000 analog input range, so adjust the formulas to work with the Arduino's 1024 analog input range.
andyx
Postby tmaros » Fri Jul 20, 2012 7:41 am
Hi!
It's an old post, but I hope someone could help me anyway. I'm trying to do aquarium controller, which should measure pH as well. I'm interfacing Arduino via LCD and buttons. I would like to have temperature compensated pH measurements, but also it would be nice to have calibration via LCD. My question is where did these "magic numbers" (in the quote) come from?
sensorValue = 7.0 - (2.5 - analogRead(sensorPinPH) / 204.8 ) / (0.257179 + 0.000941468 * sensors.getTempCByIndex(0));
What is the meaning of 0.257179 or 0.000941468?
The equation is linear, but which numbers are supposed to stay the same and which should be changed when doing calibration?
tmaros
Users browsing this forum: No registered users and 9 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
